Until now I use only classicUI. the big advantage is, that there is only one row and the item sequence is very clear and the position too.
By using BasicUI it can happen, that the place of a item switches from right to left or reverse.
This will cuase wrong actions on items because the remembered position is no longer valid. This will happen if I use visible to hide items. then my item position gets puzzeled.
