It is not RFID sensors, but SAW sensors. Basically they are though working the same. Just analog. You send in energy with an antenna and receive the energy back again, but much smaller. i.e. these can not send data on their own, but you could for example read out a window sensor every second and check if it is still closed.
You battery strategy is to have a battery change day once every year so you don’t run into trouble of having to search for the one device whose battery died this week? (If I count roughly 35 Battery devices here?)
Its a question of time how long this pulling takes…
i.e. think of this pulling taking a microsecond. So it is not that “often” that the sensor becomes active. Even if you would check the sensor once a second with 5 Sensors everything is “mostly off” or on for 5 out of 1000000 microseconds.
Conceivably you could poll less frequently but store energy for unsolicited reports?
There are venerable technologies like Modbus or even mouse that rely on polling, but in general latency is bad. An extra second delay between opening a door and the lights coming on is annoyingly noticeable to humans.
Variable poll rates are helpful, allowing sharing of available bandwidth between “important” door openings and less time sensitive temperature readings.
To paraphrase @rossko57, latency sucks, and one second is a long time. One second is fine for temperature sensors, but makes a button almost useless to me. Same could be said for a door contact if you want it to turn on the light when you walk into a room. You also have to consider the additional latency from sending reports to the system.
I don’t think this question can really be answered without more specifics, as each person’s space and needs will be different. You need to say how much range each reader has, and if range is impacted by walls/appliances. Only then can people determine whether it fits in their space.
If you’re concerned about renters, then your reader has to be something that can be plugged into a wall outlet and not require messing around with a ceiling fixture. Also, not all rooms have ceiling fixtures.
I’d go in a slightly different direction. Instead of emphasizing “one reader for lots of sensors”, focus on “an AC-powered, plug-in reader for cases where you don’t want battery-powered sensors”. As an example, a lux sensor placed outside, or a temperature sensor in a fish tank or high up a wall. I think it’s better to give it a very specific intention/purpose than to try being all things to everyone.
Does it have to be the middle? I’m considering all my rooms and the middle of the room is not a good place to put anything. Consider a bedroom. The middle of the room is the bed. In my office the middle of the room is on the floor. As I consider it, I don’t think I have a single room where I could but a device in the middle of it.
I can’t be unique in this. It would be easier to put a device like this near the center of a given floor to cover multiple rooms.
I definitely see the advantage of wireless sensors that don’t need batteries, especially for things like contacts on windows and doors.
How many sensors would this come with? It’s the sensors I care about, not the hub. In any case, 200€ is probably more than I’d pay for most of my rooms. I can get enough relatively expensive Zigbee/Zwave sensors to cover all in one room that I need for less. I may be unique but I’m not willing to pay that much of a premium to not have to change batteries that last 6+ months anyway. But I’m also not someone who has a strong interest in this anyway. Most of my windows have no sensors and I’ve no plans to add sensors to them.
MQTT support would make it instantly supported by almost all the open source home automation hubs. If you use the Homie and/or Home Assistant MQTT standard OH (and others) could even automatically discover the devices.
Thread+Matter would give you support with all the big company’s hubs and such but not openHAB at this time.
Most battery devices will report the current level. You can easily see the current levels of all your devices and change the batteries as needed.
It depends on the device and the amount of latency. Does it really matter if you learn that the window was opened one second after it actually opened? Maybe yes, maybe no. For something like temp and humidity it’s probably definitely no. Those change slowly enough that once a minute is probably overkill. But if you have a motion sensors that one second is way too long. Button presses a one second latency is too long as well. Even half a second is noticeable.
Ultimately almost everything is polling all the time. It’s usually just that the polling is taking place on the microcontroller on milliseconds timescale. Push is usually an illusion, a very helpful and convenient illusion. So I don’t have too much of an issue with a one second polling for something like this, for most sensors at least.
But I totally agree, it makes no sense to report every sensor every second. I would expect the hub to filter most of the reports out and only publish significant changes or on a longer timeframe.
Hah. I interpreted middle of the room to be a ceiling fixture, because I subconsciously ignored the idea of having a plug-in device on the floor. Now I realize that probably isn’t what’s being suggested.
The reach of passive sensors is very limited. Reading a sensor beyond 4 meters of distance becomes troublesome. Also a line of sight is necessary at this distance. Therefore an elevated position in the room with direct sight to buttons/doors/windows and being in range to windows in all directions makes the ceiling in the middle of the room the place to be. A wall-plug will just not do for this.
I also agree that depending on application different polling times are apropriate… i.e. for a button you might want a tenth of a second while the door may be fine with 2 tenths and the window can probably be slower than one poll per second.
I was also wondering what I would want from such a device, other than MQTT connectivity.
If I screwed something like this to the ceiling, for me, I thought adding some microphone to it to get simple voice command (e.g. 5 simple voice commands to run scenes in addition with the sensors “poor man’s Alexa” without any cloud connectivity is doable with a larger microcontroller).
My question here was also targeting at: Maybe someone has more/better ideas like this…
This severely limits the practicality of this design. None of my bedrooms have light fixtures on the ceiling. Most of my living spaces have chandeliers, track lighting, or recessed LED lighting. In the few rooms where I do have a light fixture in the center of the room, unless you somehow power the reader using an A19 or E17 light bulb socket while still allowing the light bulb, it will be of even further limited utility. That’s a challenge as most ceiling light fixtures don’t have room to add extra length to the light bulb. And even if that works that means you’d have to keep the light switch on at all times pretty much requiring users to deploy and use a smart bulb(s) to that fixture.
I think in order for this to be practical for enough users to make it worth while, you’ll have to figure out how to make the reader either work from a wall outlet or make the reader itself battery powered which kind of defeats the purpose, or otherwise find a solution for how to power the device. Maybe just the antenna needs to be on the ceiling and the device can be near a wall and a power plug, but that means running a wire up the ceiling which also defeats the point.
Accessing the cable the same place as your Chandelier would have been my idea for installation. And yes this forces you to have the original lightswitch all the time on while controlling the smartbulp with a switch/button. I thought this kind of setup was already pretty much standard for most rooms in the smart home. Lights are kept on all the time for smart bulps to function and being switchable.
Many of us specifically avoid smart bulbs expressly for this reason. I won’t install smart bulbs because IMO it’s far less convenient to have to interact with some app as the only way to control the lights. With smart switches I don’t have to train family and house guests on how to use the house. I don’t have to worry about someone accidentally turning off a switch. I don’t need to create some fancy tablet to allow someone to tab a screen to turn on a light.
Unless one really wants to control the color, I just don’t see the point of smart bulbs. They make things more complicated. Home automation should be about making things less complicated. Smart bulbs are a huge reason why when people bring up home automation many/most people roll their eyes.
And while I have a strong opinion on this, it’s not a unique one. There have been tomes worth written about home automation design and why to use smart switches instead of smart bulbs.
I am re-evaluating my mental image of Palais de Koshak.
On-topic
Smart bulbs? Toys for playing with, not for primary lighting. Want something disaster proof as well as visitor friendly. “Please find your phone in the dark while SuperSystem restores a corrupt file.”
A sensor “hub” might usefully add temperature and humidity sensing for little effort. Microphone and perhaps ambient light also have applications in presence sensing as well as the obvious.
Wire-free door and window sensors remain the primary attraction.
I think that’s a non-starter. It’s far more logical for a renter to attach a battery-powered sensor to a wall/window/door using 3M strips than to wire something into a ceiling light. More importantly, most renters shouldn’t be messing with high-voltage wiring.
It feels lilke you’ve come up with a technical solution, and now you’re trying to justify it for consumers. However, the only real advantage I see is that it doesn’t require batteries. Other than that, it’s not better than a Z-Wave or Zigbee sensor that has fewer physical limitations.
I’d also keep in mind that the home-automation market is small, and smaller still if you remove the people who just want to plug something into a wall and connect it to their WiFi (which is most of them).
I can see uses in commercial/industrial settings; pop a “hub” in the overhead trunking or ceiling void, powered by PoE.
On the other hand, in such settings you’ve probably already got a burglar alarm that can share its door/window events.
I have thought so too … In practice though they seem to work really well even with visitors.
i.e. They default to power on after power loss.
Meaning if a visitor switches your normal lightswitch off the light stays off… he/she will automatically press again and then the lights will go on.
Also placing switches near the normal lightswitches helps…
Its not perfect, but the smart bulps work better than I have ever expected/would not want to miss them for primary lighting.
And as with the rest of the smart home… anything that is essential is not controlled by smartphone but a physical button.
if you are looking for wireless sensors, buttons, … without batteries you may have a look at the Enocean alliance. That devices using energy harvesting and ultra low power electronics. You find that products build by different companies that licensed that technology, e.g. Eltako, Wago, Jung, Honeywell, …
I think this is a solution with way better acceptance as the passive sensor approach. I‘ve nearly changed all lights to smart lights (with different technologies from starting from Philips Hue over Tasmota-flashed WiFi-Bulbs and H801-stripe controllers and some milight-lamps to self-build pixel-led controllers) but I would never use a gateway beside every lamp on the ceiling. All doors and windows are equipped with contacts, even all my household appliances like oven, hob, dishwasher, coffeemaker, refrigerator, … are smart (Bosch/Siemens HomeConnect) so I would classify myself as an „SmartHome-Nerd“, but a classical light-switch is a must have. All of my lights are controllable with wall-switches (most of them are from HomeMatic some from EnOcean). And for all „core light“ (essential lights, not only ambiance) I have a fallback control in cases the complete SmartHome-System fails, no matter due to an software issue, gateway failure, …
Just replacing all lamps with smart lamps, no matter which technology, is not a good idea. It can always happens that a gateway fails, the wifi-AP/-Router dies, … you need to think about all contingencies.
I agree with Andreas, there is a huge potential in energy harvesting sensors.
There are today also sensors around which still have a battery but it will last over the life time of the sensor. They are either ultra energy efficient and/or use energy harvesting. I have philips hue outdoor motion sensors (incl temperatur and illuminance measurement) in place for almost 2 years and they still report 100% full battery.
