Couple different door sensors have problems sending battery status to the controller. Both are fairly new and working fine but I get nothing for battery status from them. Other identical sensors are reporting with no problem. Is there anything I can do to fix this?
Hardware:
NAS-DS01Z Door/Window Sensor
ZW089 Recessed Door Sensor Gen5
What binding version of zwave are you running?
I’m on the 2.5.0.M1 version.
One odd thing here… One of these sensors did report the battery status for about 12 hours a few days ago and then stopped. I’ve been using some REST API calls to track these in my check_mk setup.
A non-reporting battery:
A reporting battery:
Both graphs begin tracking when I first set these services in play on check_mk. The small gap on the good battery was caused by me making some tweaks to the setup.
