Joel_MELO
(Joel Melo)
November 6, 2015, 8:41am
#1
Hi everyone,
Well, I’m new with openHAB so I began by trying to get working the 1.7.1 version with the demo setup and it worked perfectly.
Now I’m trying to do same but with openHAB2 and I am not able to access http://localhost:8080/openhab.app?sitemap=demo with my browser.
I started by unzip openhab-2.0.0.alpha2-runtime.zip in C:\desktop\openHAB2
then I unziped openhab-2.0.0.alpha2-demo.zip in the same folder
Do someone have one idea to fix this issue? I’m on it from some days and feel a little frustrated
thanks a lot!
Joel_MELO
(Joel Melo)
November 6, 2015, 10:43am
#2
smhaller
(Stefan M. Haller)
November 6, 2015, 4:20pm
#3
Hi Joel,
have you tried to just point to: http://localhost:8080/ ?
It should work out of the box that way.
Good luck.
Stefan
Joel_MELO
(Joel Melo)
November 6, 2015, 6:10pm
#4
Hi Stefan,
Thanks for your reply.
Yes I did but I still get the same issue.
Moreover, I tried to do the installation in two different PCs and I get the same issue.
ptmuldoon
(Paul Muldoon)
November 6, 2015, 6:19pm
#5
Maybe a dumb question…but
Did you actually launch the ‘start.bat’ script and is java installed on the machine?
What is the error message your seeing?
Joel_MELO
(Joel Melo)
November 6, 2015, 8:47pm
#6
Yes I launched correctly the start.bat and Java is correctly installed.
I get the error “ERR_CONNECTION_REFUSED” from chrome.
Joel_MELO
(Joel Melo)
November 6, 2015, 9:43pm
#7
The weird point is that opneHAB 1.7.1 run very well on my PC. But concerning openHAB2 I am not able to get it working on my PC nor on my professional PC.
So it make think about a problem concerning the zip I downloaded…
Can someone give me another link to download openHAB2 ?
mganapa
(Mahesh Ganapathy)
November 6, 2015, 10:41pm
#8
Check the console for any errors on startup. Post the log file if possible.
Joel_MELO
(Joel Melo)
November 7, 2015, 2:23pm
#9
As I’m a newbie, I don’t know where is the log file.
I launched start_debug.bat but I do not found “openhab.log”.
Maybe I’m doing it wrong
Joel_MELO
(Joel Melo)
November 7, 2015, 7:27pm
#10
I downloaded this OH2 version from https://openhab.ci.cloudbees.com/job/openHAB2/
It works out of the box.
