HI, I am trying to create my first rule. I have an RGB connected via MQTT which works fine. I have 3 switches setup for each color (just for testing). I want to create a rule to turn off the other 2 switches when the other switch is on.
i.e. Turn on the Blue LED, then the red and green switches should turn off. I have tried but no luck.
Log show Jetty request 3053767 failed: null when trying to load the rule.
Rule is
rule Board1_BlueLEDChanged
Item Board1_BlueLED received command
if (Board1_BlueLED.state == 1) {
Board1_RedLED.sendCommand(OFF)
Board1_GreenLED.state.sendCommand(OFF)
I just realized i’ve put out opinions i really don’t have good enough knowledge about. The last thing i would do is put ut misleading information therefore i deleted my contribution. Hope i’m pardoned
