I have read many articles and forums here, but still i couldn’t decide whether i should use text file configuration or paper ui-habmin for openhab2. I tried both and at last i decided to use config files, because after creating things and items and they exceed some certain number, it seems non-manageable to do it under Paper UI. Paper UI currently has still some missing parts which i try to fill in the gap with text file configuration. On the other hand, openhab2 with textual files also have some missing parts. Like i cannot bind a channel to a rollershutter with the “invert_percent” parameter. How do we do it in openhab2 and item file? I use
{ channel = “zwave:device:adc2122e:node3:blinds_control” }
but i cannot add invert_percent=true parameter anywhere except for paper ui interface. Btw i am using Qubino ZMNHCD1 shutter module.
A second question is, using openhab2 do i have to add bindings in services/addons.cfg file or directly put the jar file to openhab2/addons folder?
