I intend to install openhab and before this I have some questions if you can help me
1 - Can i install it on a dedicated Intel NUC running latest version of Ubuntu Server?
2 - I have a raspi4 which running zigbee2mqtt and have few xiaomi temp sensors paired. Will this be compatible with open hub? I mean get sensors on mqtt?
Yes, just follow
For sure.
you only need to have and configure the right “binding” inside openhab via Paper UI for example (very easy)
Thank you very much
I will give it a try next days…I spent some time with homeassistant but seems I am not so confortable with it, that s why want to start with OpenHab
The reason for using this setup is because Intel nuc is in a dedicated technical room and Is long distance from the sensors. That s why I am using raspi with LAUNCHXL-CC26X2R1 for zigbee2mqtt where now I have just 5 xiaomi sensors but I have in plan to add lot more
Thanks for help
