@rlkoshak Based on this discussion, should I update this tutorial to use sudo shutdown -r instead of sudo reboot?
If so, am I correct that I’ll need to modify sudoers.d to:
# Allow openhab user to execute shutdown and poweroff commands
openhab ALL=(ALL) NOPASSWD: /sbin/shutdown, /sbin/poweroff
I also noted that Buster now uses systemctl reboot. So in that case, is it:
# Allow openhab user to execute systemctl command
openhab ALL=(ALL) NOPASSWD: /sbin/systemctl
And then for the commands:
sudo systemctl reboot
sudo systemctl poweroff
Or is sudo no longer necessary for Buster due to systemctl being available to all users?
