Still a beginner, so hoping i am sharing the correct info. I have a Thermostat from BeNext that is not listed in the device database. It is listed as unknown device and i guess that is also the reason for not being able to use it. Attached the corresponding xml file. Is this enough to get it included in the database or do you need additional info?
Ron
adding attachment led to an internal server error response. I will try to post it in a follow-up
