I am trying to get BeSense Motion Sensor in the Zwave database on the cd-jackson site. However when I try to add it via XML I get:
Warning
Manufacturer 7FFFFFFF is not known! Please update the manufacturer database and try again.
I looked at the XML and device and type are also set to the same value, so I take it it is an issue reading the device?
<node>
<homeId>0x2</homeId>
<nodeId>72</nodeId>
<version>4</version>
<manufacturer>0x7fffffff</manufacturer>
<deviceId>0x7fffffff</deviceId>
<deviceType>0x7fffffff</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>1000</sleepDelay>
<associationGroups class="concurrent-hash-map"/>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_BASIC</commandClass>
<COMMAND__CLASS__BASIC>
<version>0</version>
<instances>1</instances>
<versionSupported>0</versionSupported>
<isGetSupported>true</isGetSupported>
</COMMAND__CLASS__BASIC>
</entry>
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<COMMAND__CLASS__SENSOR__BINARY>
<types/>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<COMMAND__CLASS__CONFIGURATION>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>2147483647</deviceManufacturer>
<deviceType>2147483647</deviceType>
<deviceId>2147483647</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<COMMAND__CLASS__BATTERY>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>0</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>0</targetNodeId>
<interval>0</interval>
<minInterval>0</minInterval>
<maxInterval>2147483647</maxInterval>
<defaultInterval>0</defaultInterval>
<intervalStep>0</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_UNKNOWN</libraryType>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<COMMAND__CLASS__ALARM>
<alarms/>
<v1Supported>false</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>0</zwPlusVersion>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
</node>
