Hi Sifus,
I am struggling to find the best approach to tackle my challenge. Maybe someone has a good idea how to approach this “problem” with OH3 and Node-red as rule engine.
I want to implement a Wasp in a box for my presence detection.
Basically:
- motion sensor(s) in a room triggers a presence.
- 2 options now:
- all doors closed: wasp (human) is trapped in the box, presence will remain on until a door opens
- at least one door is open: wasp can escape (or not). Presence will run on a timer and eventually reset to no presence unless another presence trigger is received
The approach works like a charm when hard coded but I’m struggling to upscale this as I want to have 7 areas across the house with various numbers of presence and door sensors each. I was hoping I have some kind of grouping that puts all door sensors and motion sensors together so I just query the state of the area and would “automatically” get something like: all doors closed, motion detected which would be received as one info from the group.
Grouping into rooms via Model is kind of getting there but I would need to create sub-group just for Motion sensors and another one for door sensors. By doing so I could aggregate the status.
However checking 2 groups is kind of tricky and I need to use some naming convention and clever bridging to the other group. Is there a better way to approach it?
Second problem to this: a door sensors is the “border” to 2 areas, so the same sensor should be in 2 rooms which I trust is not possible with the Model.
Are tags of any good use of this and how could I get those in Node-red?
I can sense I miss something real simple. Usually OH presented my crazy complex ideas in a simple way, so please proof this statement right one more time and tell me that I over complicate it
(my apologies for a lengthy post)
