I am new at open hub and looking for best configuration. Now I have installed openhub2 on rpi3 and bind with max! eq3. Now i want to install openhub on existing wall switches (i need dimable option) and i also need 2pcs 12V dimmer for White led strip.
I am looking to bus UZB-1 and then buy Fibaro dimmer 2 and RGBW. Will this work normaly? Maybe is some other cheper option? Can i use Fibaro RGBW controller for 2pcs indipendent 12V white led strip?
Thanx a lot
