I am using SMA Solar system in combination with SBFspot software to read the data via Bluetooth.
The SBFspot publish the data via MQTT in the following format:
Number sma_InvTemperature “SMA InvTemperature” (Status) { channel=“mqtt:topic:mysecureBroker:sbfspot:JSONPATH($.InvTemperature)”, autoupdate=“true” }
Thing topic SMA {
Channels:
Type number : sma_temp "SMA Temperatur" [ commandTopic="sbfspot/sma_InvTemperature"]
2021-01-26 12:05:20.865 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.items'
2021-01-26 12:05:20.896 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'channel' of item 'sma_InvTemperature' could not be parsed correctly.
org.openhab.core.model.item.BindingConfigParseException: UID segment 'JSONPATH($.InvTemperature)' contains invalid characters. The last segment of the channel UID must match the pattern '[\w-]*|[\w-]*#[\w-]*'.
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.createItemChannelLink(GenericItemChannelLinkProvider.java:86) ~[?:?]
at org.openhab.core.model.thing.internal.GenericItemChannelLinkProvider.processBindingConfiguration(GenericItemChannelLinkProvider.java:76) ~[?:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:372) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:341) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:212) [bundleFile:?]
at org.openhab.core.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:407) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:301) [bundleFile:?]
at org.openhab.core.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:139) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:249) [bundleFile:?]
at org.openhab.core.model.core.internal.folder.FolderObserver.processWatchEvent(FolderObserver.java:312) [bundleFile:?]
at org.openhab.core.service.WatchQueueReader.lambda$3(WatchQueueReader.java:322) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
