I used the following countdown technique. It is over-complicated, but illustrates what you can do with OH. It allows for different run times from different triggers and/or under different conditions e.g.day/night. It allows rules to inspect unexpired countdowns and decide whether to change or leave alone.
Not usually needed in a domestic setting.
