What is the best way to integrate Velux motorised roof windows? From googling around there seem to be at least three possible options as follows. Which is best? Resp. Cheapest?
- via the Velux KLF200 hub which has an openHAB add-in
- via the Velux Active hub, which I think provides some kind of NetAtmo integration
- via the Somfy TaHoma hub, which supports Velux, and has its own openHAB add-in
