- Platform information:
- Hardware: RaspberryPi
- OS: RaspberryOS bullseye
- Java Runtime Environment: openJDK 11.0.16
- openHAB version: 3.3.0
I’ve installed 2 zigbee radiator thermostats (Hama rebrand of Tuya thermostat TZE200_yw7cahqs) in the same room.
My goal is, that changing the target temperature (manually at the phyiscal device) on any of these thermostats is propagated to the other thermostat.
Therefore I defined a new point number:temperature “GruppeThermostateHauptbad” and linked it to both target temperatures using standard profile for both channels.
All from UI, Thing definition extracted from backup:
multi-point item definition
Item.json
"GruppeThermostateHauptbad": {
"class": "org.openhab.core.items.ManagedItemProvider$PersistedItem",
"value": {
"groupNames": [
"Bad"
"itemType": "Number:Temperature",
"tags": [
"Point",
"Temperature"
"label": "Thermostate OG Hauptbad",
"category": ""
ItemChannelLink.json
"GruppeThermostateHauptbad -\u003e deconz:thermostat:8b0beb0d9f:b4e3f9fffe11f7c1010201:heatsetpoint": {
"class": "org.openhab.core.thing.link.ItemChannelLink",
"value": {
"channelUID": {
"segments": [
"deconz",
"thermostat",
"8b0beb0d9f",
"b4e3f9fffe11f7c1010201",
"heatsetpoint"
"uid": "deconz:thermostat:8b0beb0d9f:b4e3f9fffe11f7c1010201:heatsetpoint"
"configuration": {
"properties": {}
"itemName": "GruppeThermostateHauptbad"
"GruppeThermostateHauptbad -\u003e deconz:thermostat:8b0beb0d9f:cc86ecfffef0464f010201:heatsetpoint": {
"value": {
"channelUID": {
"segments": [
"deconz",
"thermostat",
"8b0beb0d9f",
"cc86ecfffef0464f010201",
"heatsetpoint"
"uid": "deconz:thermostat:8b0beb0d9f:cc86ecfffef0464f010201:heatsetpoint"
"configuration": {
"properties": {}
Current behaviour
- Changing the point “GruppeThermostateHauptbad” in openhab is propagated to both devices - as expected
- Manually changing the target temperatur on a device updates the corresponding openhab item/point and the point “GruppeThermostateHauptbad”, but this is not propagated to the other thermostat - which is my goal
What am I missing?
Is there any way to achieve my goal, without defining rules reacting on manual changes on the thermostats?
