Looking for ideas on best way to do this.
To change the weather display on the nspanel you need to send a message with two elements.
nspsend {"HMI_weather":32,"HMI_outdoorTemp":7}
These are two openhab items taken from openweather binding.
Originally I had a rule on change of each which sent a command to the corresponding mqtt item on the NSpanel, so a change it temp would send the
{"HMI_outdoorTemp":7}
However this doesn’t work bc the command needs both parts to be valid.
I know I could make the script actually make the json string from both parts and set that as the item like
and have no formatting on the channel. This would work I’m sure, but it would mean you see the actual json in the item, which feels a little clunky. Is there a better way?
Is it possible to send direct to the channel from the script, without an item? As I dont really need or want to see this internal item with the json in. feels a fudge to have it.
This works, but is it best way?
events.sendCommand("ns_temperature",""+ir.getItem("CabinDevices_CabinRoomTemperature").state.intValue())
Properties map = new Properties()
File file = new File("../conf/transform/weather.map")
map.load(new FileReader(file))
def weather = map.getProperty(ir.getItem("LocalWeatherandForecast_WeatherConditionId").state.toString())
def outdoorTemp = ir.getItem("outdoor_temp").state.intValue()
def apparentTemp = ir.getItem("apparent_temperature").state.intValue()
def json = String.format(
"{\"HMI_weather\":%s,\"HMI_outdoorTemp\":{\"current\":%d,\"range\":\"%d,%d\"}}",
weather, outdoorTemp, apparentTemp, apparentTemp)
events.sendCommand("nspsend_command",json)
