So here are the mentioned log entries, that are shown red and the beginning of the change of the tuneinradiostation:
2018-03-07 19:27:54.202 [vent.ItemStateChangedEvent] - EchoImSchlafzimmer_TuneInRadioStationsID changed from to 0
2018-03-07 19:27:59.511 [WARN ] [mazonechocontrol.internal.Connection] - Parsing json failed {}
com.google.gson.JsonSyntaxException: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 5 column 1 path $
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:224) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:887) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:852) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:801) ~[?:?]
at com.google.gson.Gson.fromJson(Gson.java:773) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.parseJson(Connection.java:472) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlayer(Connection.java:491) ~[?:?]
at org.openhab.binding.amazonechocontrol.handler.EchoHandler.updateState(EchoHandler.java:396) ~[?:?]
at org.openhab.binding.amazonechocontrol.handler.EchoHandler.lambda$0(EchoHandler.java:356) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.lang.IllegalStateException: Expected BEGIN_OBJECT but was STRING at line 5 column 1 path $
at com.google.gson.stream.JsonReader.beginObject(JsonReader.java:385) ~[?:?]
at com.google.gson.internal.bind.ReflectiveTypeAdapterFactory$Adapter.read(ReflectiveTypeAdapterFactory.java:213) ~[?:?]
… 15 more
2018-03-07 19:27:59.540 [WARN ] [mazonechocontrol.internal.Connection] -
(function(d,e){function h(f,b){if(!(a.ec>a.mxe)&&f){a.ter.push(f);b=b||{};var c=f.logLevel||b.logLevel;c&&c!==k&&c!==m&&c!==n&&c!==p||a.ec++;c&&c!=k||a.ecf++;b.pageURL=“”+(e.location?e.location.href:“”);b.logLevel=c;b.attribution=f.attribution||b.attribution;a.erl.push({ex:f,info:b})}}function l(a,b,c,e,g){d.ueLogError({m:a,f:b,l:c,c:“”+e,err:g,fromOnError:1,args:arguments},g?{attribution:g.attribution,logLevel:g.logLevel}:void 0);return!1}var k=“FATAL”,m=“ERROR”,n=“WARN”,p=“DOWNGRADED”,a={ec:0,ecf:0, pec:0,ts:0,erl:,ter:,mxe:50,startTimer:function(){a.ts++;setInterval(function(){d.ue&&a.pec<a.ec&&d.uex(“at”);a.pec=a.ec},1E4)}};l.skipTrace=1;h.skipTrace=1;h.isStub=1;d.ueLogError=h;d.ue_err=a;e.onerror=l})(ue_csm,window);
and
q(“:”,g.attribution||d.attribution,d.name);g.logLevel=d.logLevel;g.attribution&&console&&console.log&&console.log([g.logLevel||“ERROR”,a,“thrown by”,g.attribution].join(" “));C=;fa&&(d=.slice.call(arguments),d[4]=g,fa.apply(f,d))};D.prototype={logError:function(a,b,c,e){b={message:b,logLevel:c||“ERROR”,attribution:q(”:“,this.attribution,e)};if(f.ueLogError)return f.ueLogError(a||b,a?b:null),!0;console&&console.error&&(console.log(b),console.error(a));return!1},error:function(a,b,c,e){a=Error(q(”:",
it seems somewhere above the posted sourceparts of the error there is a warning
[WARN ] [mazonechocontrol.handler.EchoHandler] - Get notification sounds failed: {} …
... 80 more
