Hi, I assume you used the new login method with the webbrowser? Regards, Michael
UPDATE: Sorry, I have not read your text exactly, I have seen already that you used the web browser method!
Hi, it seems to be the same issue which have @Silberbaum already reported. Have you seen the login screen multiple times while the login process? E.g. the captcha was not entered correct or appears as second step?
I will work on this issue, but it can take a little bit to fix it, I’am currently very busy.
Regards,
Michael
But that may be the problem also.
On my laptop I didn’t got a captcha - of course.
But I possibly would get one via the raspberry.
Because these was never connected to amazon before.
But there is no graphical UI installed on the raspberry …
So the only way (see above) was blocked.
isnt possible the right url for you.
If you look via PaperUI within things, you should see you amazon account, and right beneath it the thing id. e.g.: amazonechocontrol:account:account1 or amazonechocontrol:account:742ab3
Status update to login problems
I found out with @Silberbaum that amazon have one more protection for the login. In this case, a code must be entered which will be sent by notification or email. I’am currently testing if it is possible to support this.
Regards,
Michael
