Thanks Michael, I will check that out!
Hi Michi,
Been playing with this binding for a few days now and I love it. Thanks for all the effort!
I have a question though.
I need to be able to play and alarm as soon as my wireless doorbell is pushed , but I do not want the default sound.
In your original post it states :
playAlarmSound String R/W echo, echoshow, echospot, unknown Write Only! Plays an alarm sound. In PaperUI will be a selection box available. For rules use the value shown in the square brackets
Can you please clarify and/or give a full example of how I could go about playing the āNightstandā sound through my echo for 5 seconds without changing the default sound permanently , or changing it back to the default one afterwards ?
Thanks in advance,
Jeroen
Hello Michael,
I use your Binding since a few days, and it works fineā¦ good job.
I just have only one problem with the volume control.
I use 2 Echo Dot and 1 Echo plus. For the Dots evrything is ok. The slider will show the current volume level and i can raise up and down the volume.
For the Echo plus I also can adjust the volume level and the Echo change to the new level, but the slider always go back to zero. That means I will never know which level th Echo Plus haveā¦
Pherhaps IĀ“m not the only person with this problemā¦
THX
Is there any way that I can add https://amazon.in in this binding because iām in india and if I select amazon.com it is not showing any status of itemsā¦
Dear Michael,
first of all thank you for the great work you did on this binding.
Just started playing around with it and alreday love it.
So far I was only able to configure it, using PaperUI.
Creating the amazonechocontrol.thing file manualy (by your example file) nothing happens / and no error is logged. As I prefer thing.files due to better backup possibilities, is that possible ?
Best wishes
Mike
Hi Yash_Shah,
just type amazon.in in the configuration of the amazon site. Anyway I will at it to the selection box for more comfort in the next version.
Regards,
Michael
Hi Mike,
yes it is possible, maybe you post your file (replace your account information with āxā). It seems that something is wrong.
Regards,
Michael
Hi Daniel,
Are you sure that you have configured everything right. It looks like that you have configured the volume channel for a multiroom music room.
Regards,
Michael
Hi Jeroen,
Maybe an other use can help you with this, Iāam currently very busy. If not I will trie to give you a better example if I have a litte bit more time.
Regards,
Michael
Thank you very much for responding. Not a problem at all. Cheers
I had configure it like my other 2 dotsā¦
Tutorial for playing an alarm sound with an openHAB rule:
- Open the PaperUI
- Navigate to the Control Section
- Open the Drop-Dow
- Select the Sound you want to here
- Write down the text in the square brackets. e.g. ECHO:system_alerts_repetitive01 for the nightstand sound
- Create a rule for start playing the sound:
var Timer stopAlarmTimer = null
rule "Turn on alarm sound for 15 seconds if door opens"
Item Door_Contact changed to OPEN
Echo_Living_Room_PlayAlarmSound.sendCommand('ECHO:system_alerts_repetitive01')
if (stopAlarmTimer === null)
stopAlarmTimer = createTimer(now.plusSeconds(15)) [|
stopAlarmTimer.cancel()
Echo_Living_Room_PlayAlarmSound.sendCommand('')
Note 1: Do not use a to short time for playing the sound, because alexa needs some time to start playing the sound. I recommend, that you to not use a time below 10 seconds.
Note 2: The rule have no effect for your default alarm sound used in the alexa app.
Regards,
Michael
Thank you very much Michi. Implemented it and it is exactly what I was after !
Cheers,
Jerre
Hi.
Sorry, but i canāt find my answers.
How can i let the echo speak a written text. But not as a reminder?
Why i have the thing xxxAlexa Apps in the inbox? It changes everytime from online to offline.
I have found all 5 echos but there ist another one with āthis deviceā and a longer serial number. Canāt find it in the app. The fire TV stick is found but changes from online to offline too.
Thanks,
Markus
Sorry,
can i start a saved scene of hue lights with āstart Routineā?
Thanks again,
Markus
I donāt think this is possible yet, only possible as a reminder.
This is most likely the Alexa App on your phone or tablet.
Donāt own one but could be that your TV is OFF when it goes offline?
Yes, confirmed
Hi, Yash_Shah,
no there is no other option. I donāt know if something is different at amazon.in. For the other domains there was no difference, except the login process. Maybe you can more clarify whats going on. Have you created the account thing in paperUI? What status is shown in the Thing? Are there any errors listed in the log-file?
Regards,
Michael
Hi Markus,
if you can define a routine in the alexa app which does what you want, the answer is yes, because you can trigger it with the start Routine. If the answer is no, than there is no possibility, because the binding can only start existing routines.
Regards,
Michael
