[beta testers wanted!] Jython addon w/ helper libraries (requires OH 2.5.x)
I think all the helper libraries for OH3 are still missing or not updated to use in OH3. You could use python in your rules, but all the imports still do not work:
e.g.
from core.rules import rule
from core.triggers import when
from core.log import logging, LOG_PREFIX
from core.actions import Transformation
Exactly!
It looks like the Helper library will make sense for Jython file rules, but are not necessary for the Jython UI rules approach? I haven’t installed OH3 yet, but are there mechanisms to group UI rules somehow? The number of rules I have implemented will be far to big to have them in one long list…
Yes using the helper library probably makes the most sense when creating file based rules.
Currently you can only filter rules based on their name. I think adding additional ways to filter/group items/rules/things might make sense for OH 3.1+.
The Demo has been updated to OH3 so you can give it a try without installing anything :slight_smile:
https://demo.openhab.org/ (to login to admin mode use username: demo and password: demo)
I’ve just tried updating from OH2 to OH3 RC2, installed the Jython scripting automation addon, but my scripts aren’t running. It seems that the helper libraries need to be updated.
Sorry I tried to look but haven’t managed to find it. Where can I find the jython helper libraries for OH3? Is it not publicly available yet?
10 posts above yours!
Either you misunderstood my question or I misunderstood your suggestion. I have already got Jython Scripting installed. I was asking about the jython helper libraries, not the Jython scripting support.
I had the jython helper libraries from OH2 in my conf/automation/ folder as it was running on OH2. They produced errors in OH3:
2020-12-21 17:42:04.292 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2020-12-21 17:42:04.292 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py'
2020-12-21 17:42:04.735 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_OsgiEventTrigger.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2020-12-21 17:42:04.736 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_StartupTrigger.py'
2020-12-21 17:42:05.221 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_StartupTrigger.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2020-12-21 17:42:05.222 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py'
2020-12-21 17:42:05.652 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonBindingInfoProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2020-12-21 17:42:05.654 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py'
2020-12-21 17:42:06.152 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonExtensionProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2020-12-21 17:42:06.153 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py'
2020-12-21 17:42:06.647 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonItemChannelLinkProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2020-12-21 17:42:06.647 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py'
2020-12-21 17:42:07.319 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonItemProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 6
2020-12-21 17:42:07.320 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py'
2020-12-21 17:42:07.896 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonThingProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2020-12-21 17:42:07.897 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py'
2020-12-21 17:42:08.461 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonThingTypeProvider.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 5
2020-12-21 17:42:08.462 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/200_JythonTransform.py'
2020-12-21 17:42:08.903 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/200_JythonTransform.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 7
I think you have misunderstood.
Again:
To be clear: the Jython helper libraries are not available for OH3 at the moment.
I’ve uploaded my temporary fix for the jython helper libraries. Details can be found here: Jython helper libraries for OH3
Is there any news about getting things running in OH3 as good as it is in OH2.5?
I thought it was already in OH3.
There is an open PR that make the Jython libraries compatible with OH3. You will need to install the Jython automation addon and follow the manual installation instructions in the HL docs to use it.
It works fine with OH3 with the linked PR for me. There was some difficulties but only because of Joda time - Java time change.
I’m having some issues getting the patched Jython libraries working.
My set up:
  1. Docker image: openhab-3.1.0-snapshot (arm64)
  2. Jython automation bundle installed
  3. Files copied into /jsr223/python/core and /lib/python/core
  4. Configuration.py set up
Logs:
2021-01-06 13:09:50.028 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/London'.
2021-01-06 13:09:50.158 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '52.40304863399438,-1.8824170479174995'.
2021-01-06 13:09:50.177 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_GB'.
2021-01-06 13:10:06.222 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2021-01-06 13:10:06.998 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2021-01-06 13:10:13.554 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-01-06 13:10:15.822 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:15.827 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:15.839 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:15.843 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:15.847 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:15.865 [INFO ] [ab.core.service.AbstractWatchService] - ScriptEngine for py not available
2021-01-06 13:10:20.667 [INFO ] [org.openhab.ui.internal.UIService   ] - Started UI on port 9080
2021-01-06 13:10:20.841 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2021-01-06 13:10:26.919 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = feb126b2-dea5-4766-a20f-959231dea89c, base URL = http://localhost:9080)
2021-01-06 13:10:28.017 [INFO ] [internal.ModuleHandlerFactoryStarter] - WebPushNotificationModuleHandlerFactory started by ModuleHandlerFactoryStarter
2021-01-06 13:10:28.706 [INFO ] [hab.ui.habot.tile.internal.HABotTile] - Started HABot at /habot
2021-01-06 13:10:29.221 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2021-01-06 13:10:35.805 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/000_Startup.py'
2021-01-06 13:10:38.512 [WARN ] [jython.startup                      ] -
Jython version:             2.7.2.final
Operating system:           Linux
OS Version:                 5.4.0-1025-raspi
Java vendor:                Azul Systems, Inc.
Java VM name:               OpenJDK 64-Bit Server VM
Java runtime name:          OpenJDK Runtime Environment
Java runtime version:       11.0.9+11-LTS
configuration.py installed: True
sys.path:                   /openhab/conf/automation/lib/python
                            /openhab/userdata/cache/org.eclipse.osgi/270/0/bundleFile/Lib
                            __classpath__
                            __pyclasspath__/
2021-01-06 13:10:38.517 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py'
2021-01-06 13:10:40.099 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_StartupTrigger.py'
2021-01-06 13:10:40.954 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/cron.py'
2021-01-06 13:10:46.124 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/hello_world.py'
2021-01-06 13:10:48.980 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/new_hello_world.py'
So OH3 can detect and run at least some .py files but the hello_world.py does not run. It seems to parse the rule and is listed but I get no output in the logs that it’s running.
Any ideas what to try?
Done the same on the OH 3.0.0 docker installation:
2021-01-06 12:45:03.405 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/000_Startup.py'
2021-01-06 12:45:05.507 [WARN ] [jython.startup                      ] -
OS Version:                 5.4.72-v7l+
Java VM name:               OpenJDK Client VM
configuration.py installed: False
                            /openhab/userdata/cache/org.eclipse.osgi/214/0/bundleFile/Lib
                            __classpath__
                            __pyclasspath__/
2021-01-06 12:45:05.509 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py'
2021-01-06 12:45:07.481 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/core/components/100_DirectoryTrigger.py': java.lang.NullPointerException: java.lang.NullPointerException in <script> at line number 8
2021-01-06 12:45:07.483 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/core/components/100_StartupTrigger.py'
2021-01-06 12:45:10.073 [WARN ] [jython.core.log                     ] - The 'configuration.py' file is missing from teh python.path!
2021-01-06 13:00:52.784 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/Hello.py'
2021-01-06 13:00:55.469 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/Hello.py'
2021-01-06 13:01:22.180 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/Hello.py'
2021-01-06 13:01:26.262 [WARN ] [jython.core.log                     ] - The 'configuration.py' file is missing from teh python.path!
2021-01-06 13:01:26.953 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/openhab/conf/automation/jsr223/python/personal/Hello.py': ImportError: No module named joda in <script> at line number 6
Only error messages no output at all.
The hello world example:
This script uses a decorated cron rule that will generate logs every 10s and can be used to test your initial setup.
@rule("Jython Hello World (cron decorators)", description="This is an example cron triggered rule using decorators", tags=["Test tag", "Hello World"])# description and tags are optional
@when("Time cron 0/10 * * * * ?")
def hello_world_cron_decorators(event):
hello_world_cron_decorators.log.info("Hello World!")
Hi @lukics - it looks like you haven’t set up configuration.py. It should be in /lib/python/configuration.py
RTFM!?, thanks
@danielwalters86 please post more of your log. Do you see warn entries like lukics?
@lukics you are indeed missing the configuration.py file, but that is not why the hello.py script is not loading. I see a warning in your log saying that joda cannot be imported, if you were indeed running the patch from PR #376 you would not see this error. Please make sure that you updated to the correct version.
@CrazyIvan359 I have updated my post with a longer log.
Edit: This is strange. I tried to debug what was going on so I ssh’d into the karaf console and issued the command log:set DEBUG at 13:55 and all of a sudden I had output in the logs…
2021-01-06 13:55:10.360 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin nofification (configuration successful) to org/ops4j/pax/logging/Configuration
2021-01-06 13:55:20.088 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:55:20.226 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:55:30.088 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:55:30.226 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:55:38.269 [DEBUG] [e.osgi.LoggingCommandSessionListener] - Executing command: 'log:set INFO'
2021-01-06 13:55:38.277 [DEBUG] [org.apache.felix.configadmin        ] - getConfiguration(pid=org.ops4j.pax.logging, location=null)
2021-01-06 13:55:38.279 [DEBUG] [org.apache.felix.configadmin        ] - Found cached configuration org.ops4j.pax.logging bound to ?
2021-01-06 13:55:38.298 [DEBUG] [org.apache.felix.configadmin        ] - update(properties={felix.fileinstall.filename=file:/openhab/userdata/etc/org.ops4j.pax.logging.cfg, org.ops4j.pax.logging.log4j2.config.file=/openhab/userdata/etc/log4j2.xml, service.pid=org.ops4j.pax.logging})
2021-01-06 13:55:38.300 [DEBUG] [org.apache.felix.configadmin        ] - Updating config org.ops4j.pax.logging with {felix.fileinstall.filename=file:/openhab/userdata/etc/org.ops4j.pax.logging.cfg, org.ops4j.pax.logging.log4j2.config.file=/openhab/userdata/etc/log4j2.xml, service.pid=org.ops4j.pax.logging}
2021-01-06 13:55:38.304 [DEBUG] [org.apache.felix.configadmin        ] - No SynchronousConfigurationListeners to send CM_UPDATED event to.
2021-01-06 13:55:38.306 [DEBUG] [org.apache.felix.configadmin        ] - Scheduling task Fire ConfigurationEvent: pid=org.ops4j.pax.logging
2021-01-06 13:55:38.308 [DEBUG] [org.apache.felix.configadmin        ] - Running task Fire ConfigurationEvent: pid=org.ops4j.pax.logging
2021-01-06 13:55:38.310 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.osgi.service.cm.ConfigurationListener, id=47, bundle=16/mvn:org.apache.karaf.shell/org.apache.karaf.shell.core/4.2.7]
2021-01-06 13:55:38.312 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.osgi.service.cm.ConfigurationListener, id=122, bundle=9/mvn:org.apache.felix/org.apache.felix.configadmin/1.9.16]
2021-01-06 13:55:38.313 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener, id=292, bundle=163/mvn:org.openhab.core.bundles/org.openhab.core.karaf/3.1.0-SNAPSHOT]
2021-01-06 13:55:38.315 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.osgi.service.cm.ConfigurationListener, id=133, bundle=46/mvn:org.apache.aries.jax.rs/org.apache.aries.jax.rs.whiteboard/1.0.9]
2021-01-06 13:55:38.316 [DEBUG] [org.apache.felix.configadmin        ] - Scheduling task Update: pid=org.ops4j.pax.logging
2021-01-06 13:55:38.319 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.osgi.service.cm.ConfigurationListener, id=76, bundle=53/mvn:org.apache.karaf.config/org.apache.karaf.config.core/4.2.7]
2021-01-06 13:55:38.319 [DEBUG] [org.apache.felix.configadmin        ] - Running task Update: pid=org.ops4j.pax.logging
2021-01-06 13:55:38.320 [DEBUG] [org.apache.felix.configadmin        ] - UpdateConfiguration(org.ops4j.pax.logging) scheduled
2021-01-06 13:55:38.322 [DEBUG] [org.apache.felix.configadmin        ] - Updating configuration org.ops4j.pax.logging to revision #4
2021-01-06 13:55:38.324 [DEBUG] [org.apache.felix.configadmin        ] - canReceive=true; bundle=mvn:org.ops4j.pax.logging/pax-logging-log4j2/1.11.2; configuration=? (no SecurityManager)
2021-01-06 13:55:38.325 [DEBUG] [e.osgi.LoggingCommandSessionListener] - Command: 'log:set INFO' returned 'null'
2021-01-06 13:55:38.324 [DEBUG] [org.apache.felix.configadmin        ] - Sending CM_UPDATED event for org.ops4j.pax.logging to [org.osgi.service.cm.ConfigurationListener, id=134, bundle=46/mvn:org.apache.aries.jax.rs/org.apache.aries.jax.rs.whiteboard/1.0.9]
2021-01-06 13:55:38.432 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin nofification (configuration successful) to org/ops4j/pax/logging/Configuration
2021-01-06 13:55:40.090 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:55:40.226 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:55:50.089 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:55:50.226 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:00.089 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:56:00.227 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:10.089 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:56:10.228 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:20.091 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:56:20.228 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:30.090 [INFO ] [Jython Hello World (cron decorators)] - Hello World!
2021-01-06 13:56:30.228 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:32.008 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/hello_world.py'
2021-01-06 13:56:40.229 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:40.908 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:56:50.229 [INFO ] [jsr223.jython.Rule Name             ] - Hello World!
2021-01-06 13:56:50.344 [INFO ] [ab.core.service.AbstractWatchService] - Loading script '/openhab/conf/automation/jsr223/python/personal/cron.py'
2021-01-06 13:56:50.906 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:00.681 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:00.907 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:10.684 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:10.907 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:20.683 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:20.907 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:30.684 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:30.909 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:40.684 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:40.910 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:57:50.685 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:57:50.908 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
2021-01-06 13:58:00.688 [INFO ] [jsr223.jython.Rule Name             ] - Hello World! (cron.py)
2021-01-06 13:58:00.909 [INFO ] [Jython Hello World (cron decorators)] - Hello World! (hello_world.py)
@danielwalters86 I don’t see that anything would have changed, but glad it’s working now
