Quick question, I have an existing squeezeplayer power switch item (on/off) that I also want to control via
MQTT (old binding).
Is there any way I can enable this for the existing switch item, or do I need to create a proxy item and add a rule to toggle the real switch item if the proxy item is changed?
@sihui thank you, are there any examples how this would look like with MQTT channels?
And: How to do this if I have the Item not defined in the files but in the jsondb?
How would I create this item in the textfile, linked to that channel, does this just have to be:
channel=“squeezebox:squeezeboxplayer:f3ddcc30:b827eb564bf4:power”
