adisD
(Adis Delalic)
January 12, 2022, 4:36pm
#1
Hello everyone,
Hardware: Raspberry PI
OS: Openhabian_
Java Runtime Environment: which java platform is used and what version
openHAB version:3.2
I have got some Sonoff Wifi door sensors (ordered by mistake). Based on that I would like to know whether wifi sensors fit with OH.
I am informed on data transport and high battery usage issues. I was not able to find a tutorial that covers this topic.
Question that I have is whether I should stop any further investigation, but rather order zigbee enabled eqyipment instead of?
Or if it is there an appropriate binding and approach that can address my use case and spare nature for garbage?
thanks in advance
Adis
Is it this one?
If so, looks like it can be flashed with Tasmota. You would then communicate via MQTT. If you know only some of these words turn there’s a fair bit of learning.
Or search this forum for a Sonoff or Ewelink binding - I think there’s one floating around… and here it is, first hit. Not sure if it’s compatible though:
Control of sonoff and other brands using the ewelink platform.
Local and cloud control is available.
Device discovery included.
2.5.x and 3.x available
The binding currently has limited device support listed below, however if you send me the debug log under ‘Discovery Response’ or the file created under userdata/sonoff after adding your account I will get them added.
Please refer to the readme below. Pre-compiled Jar files are available for each branch (2.5.x and 3.x)
Precompiled Jars:
