Hey guys,
I wanted to start with binding development today and followed the Openhab2 Binding Development Tutorial. But on running the create_openhab_binding_skeleton.sh I get the following error:
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 06:13 min
[INFO] Finished at: 2017-01-02T11:43:57+01:00
[INFO] Final Memory: 23M/212M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:2.4:generate (default-cli) on project pom: The desired archetype does not exist (org.eclipse.smarthome.archetype:org.eclipse.smarthome.archetype.binding:0.9.0-SNAPSHOT) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
Any idea why this happens?
Thank you very much!
