@hww3 hi Bill, it’s much stable right now. I am using only ON/OFF power switch combined to motion sensor rule. I am turning ON the apple tv after 30 sec of constant presence detection. What i see is sometimes dont’t know when and when the apple tv is off the commands are not working. It’s not powering on i need to bring it on with a remote. The item linked to powerswitch has “ON” but it’s not true
2025-09-13 22:59:33.601 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-13 22:59:33.602 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-13 22:59:33.602 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@49df3738
2025-09-13 22:59:33.603 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-13 22:59:33.607 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 298746
2025-09-13 22:59:33.612 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-13 22:59:40.943 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-13 22:59:40.943 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-13 22:59:40.944 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-13 22:59:40.947 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:18:41.795 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 06:18:41.798 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:18:41.799 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 06:18:41.799 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 06:18:41.801 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 06:20:31.499 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 06:25:31.535 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 06:30:31.496 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 06:33:41.802 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 06:33:41.803 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 06:33:41.803 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@77110d6c
2025-09-14 06:33:41.804 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 06:33:41.810 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 324755
2025-09-14 06:33:41.812 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 06:33:50.202 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:33:50.203 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 06:33:50.203 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 06:33:50.206 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:33:50.207 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 06:33:50.207 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 06:33:50.209 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 06:45:31.502 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 06:48:50.210 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 06:48:50.211 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 06:48:50.212 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@4208853f
2025-09-14 06:48:50.212 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 06:48:50.219 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 325594
2025-09-14 06:48:50.220 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 06:48:58.668 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:48:58.669 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 06:48:58.669 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 06:48:58.671 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 06:48:58.672 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 06:48:58.672 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 06:48:58.674 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 06:55:31.501 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:00:00.516 [DEBUG] [time.internal.engine.DSLScriptEngine] - Script uses context 'irrigation-6'.
2025-09-14 07:00:31.554 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:03:58.675 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 07:03:58.675 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 07:03:58.676 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@729ad2d6
2025-09-14 07:03:58.676 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 07:03:58.681 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 326439
2025-09-14 07:03:58.683 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 07:04:05.751 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:04:05.751 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 07:04:05.751 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 07:04:05.754 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:04:05.754 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 07:04:05.755 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 07:04:05.756 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 07:05:31.523 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:10:31.526 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:15:31.579 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:19:05.757 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 07:19:05.758 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 07:19:05.758 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@6afe403a
2025-09-14 07:19:05.759 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 07:19:05.763 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 327159
2025-09-14 07:19:05.768 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 07:19:13.063 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:19:13.064 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 07:19:13.065 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 07:19:13.067 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:19:13.068 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 07:19:13.068 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 07:19:13.070 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 07:20:31.543 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:25:31.545 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:30:31.593 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:34:13.070 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 07:34:13.071 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 07:34:13.071 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@37f664a9
2025-09-14 07:34:13.071 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 07:34:13.076 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 327858
2025-09-14 07:34:13.078 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 07:34:20.345 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:34:20.346 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 07:34:20.346 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 07:34:20.349 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:34:20.350 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 07:34:20.350 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 07:34:20.352 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 07:35:31.627 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:40:31.560 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:45:31.539 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:49:20.353 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 07:49:20.353 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 07:49:20.354 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@16464620
2025-09-14 07:49:20.354 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 07:49:20.360 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 328560
2025-09-14 07:49:20.364 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 07:49:27.613 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:49:27.614 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 07:49:27.615 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 07:49:27.618 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 07:49:27.618 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 07:49:27.619 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 07:49:27.620 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 07:50:31.571 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 07:55:31.564 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:00:00.524 [DEBUG] [time.internal.engine.DSLScriptEngine] - Script uses context 'irrigation-6'.
2025-09-14 08:00:31.740 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:04:27.621 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 08:04:27.622 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 08:04:27.622 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@60ca9b66
2025-09-14 08:04:27.623 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 08:04:27.627 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 329250
2025-09-14 08:04:27.632 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 08:04:34.867 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:04:34.867 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 08:04:34.868 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 08:04:34.871 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:04:34.871 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 08:04:34.872 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 08:04:34.874 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 08:05:31.663 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:10:31.582 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:15:31.578 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:19:34.875 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 08:19:34.876 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 08:19:34.876 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@112d1723
2025-09-14 08:19:34.877 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 08:19:34.881 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 329925
2025-09-14 08:19:34.900 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 08:19:42.095 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:19:42.096 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 08:19:42.096 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 08:19:42.100 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:19:42.101 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 08:19:42.101 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 08:19:42.103 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 08:20:31.583 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:24:13.389 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve4InUse, State NULL (UnDefType)
2025-09-14 08:24:13.390 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve4SetDuration. Returning default value 0
2025-09-14 08:24:13.392 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF irrigationSystemTotalRemaining. Returning default value 0
2025-09-14 08:24:13.393 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve3InUse, State NULL (UnDefType)
2025-09-14 08:24:13.394 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve3SetDuration. Returning default value 0
2025-09-14 08:25:31.563 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:27:29.300 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-09-14 08:27:29.346 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = aa...27, base URL = http://localhost:8080)
2025-09-14 08:27:29.595 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve4InUse, State NULL (UnDefType)
2025-09-14 08:27:29.615 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve4SetDuration. Returning default value 0
2025-09-14 08:27:29.630 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF irrigationSystemTotalRemaining. Returning default value 0
2025-09-14 08:27:29.638 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve3InUse, State NULL (UnDefType)
2025-09-14 08:27:29.641 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve3SetDuration. Returning default value 0
2025-09-14 08:27:33.612 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = aa...27, base URL = http://localhost:8080)
2025-09-14 08:28:30.259 [INFO ] [y.internal.handler.ShellyBaseHandler] - shelly1minig3-34b7dac70f6c: INFO: New firmware available: current version: 1.6.2-, new version: 1.7.0
2025-09-14 08:30:31.637 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:34:42.107 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 08:34:42.122 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 08:34:42.128 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@73e317ae
2025-09-14 08:34:42.147 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 08:34:42.170 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 330686
2025-09-14 08:34:42.177 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 08:34:50.141 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:34:50.145 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 08:34:50.158 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 08:34:50.286 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:34:50.288 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 08:34:50.288 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 08:34:50.331 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 08:35:31.585 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:40:31.571 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:45:31.619 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:49:50.332 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 08:49:50.336 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 08:49:50.337 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@4390f01c
2025-09-14 08:49:50.340 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 08:49:50.351 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 331409
2025-09-14 08:49:50.356 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 08:49:57.897 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:49:57.898 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 08:49:57.898 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 08:49:57.905 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 08:49:57.908 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 08:49:57.910 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 08:49:57.919 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 08:50:31.634 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 08:51:01.171 [INFO ] [nternal.handler.SonoffAccountHandler] - Updating Sonoff Access Tokens
2025-09-14 08:55:31.604 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:00:00.553 [DEBUG] [time.internal.engine.DSLScriptEngine] - Script uses context 'irrigation-6'.
2025-09-14 09:00:31.629 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:04:57.920 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 09:04:57.920 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 09:04:57.921 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@7f73b85e
2025-09-14 09:04:57.921 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:04:57.928 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 332092
2025-09-14 09:04:57.929 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 09:05:05.318 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:05:05.319 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 09:05:05.319 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 09:05:05.325 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:05:05.325 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 09:05:05.326 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 09:05:05.328 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 09:05:31.599 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:10:31.593 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:12:25.768 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@19f05327' takes more than 5000ms.
2025-09-14 09:13:01.900 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2025-09-14 09:13:01.901 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = aa...27, base URL = http://localhost:8080)
2025-09-14 09:13:03.139 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve4InUse, State NULL (UnDefType)
2025-09-14 09:13:03.143 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve4SetDuration. Returning default value 0
2025-09-14 09:13:03.144 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF irrigationSystemTotalRemaining. Returning default value 0
2025-09-14 09:13:03.146 [DEBUG] [ternal.accessories.BooleanItemReader] - Unexpected item state, returning false. Item valve3InUse, State NULL (UnDefType)
2025-09-14 09:13:03.147 [DEBUG] [ssories.HomekitCharacteristicFactory] - Item state NULL is UNDEF valve3SetDuration. Returning default value 0
2025-09-14 09:13:03.458 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = aa...27, base URL = http://localhost:8080)
2025-09-14 09:15:31.559 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:20:05.328 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 09:20:05.331 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 09:20:05.332 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@6d83513d
2025-09-14 09:20:05.333 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:20:05.339 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 332860
2025-09-14 09:20:05.341 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 09:20:13.806 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:20:13.807 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 09:20:13.807 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 09:20:13.809 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:20:13.809 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 09:20:13.810 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 09:20:13.812 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 09:20:31.562 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:30:31.571 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:35:13.812 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 09:35:13.813 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 09:35:13.814 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@101cfb6f
2025-09-14 09:35:13.814 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:35:13.821 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 333732
2025-09-14 09:35:13.826 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 09:35:22.338 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:35:22.339 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 09:35:22.340 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 09:35:22.344 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:35:22.344 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 09:35:22.345 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 09:35:22.347 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 09:40:31.565 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:50:22.347 [INFO ] [ding.appletv.internal.AppleTVHandler] - Starting Apple-TV discovery
2025-09-14 09:50:22.348 [INFO ] [enhab.binding.appletv.internal.PyATV] - Scan for AppleTV devices
2025-09-14 09:50:22.349 [INFO ] [enhab.binding.appletv.internal.PyATV] - Sending command scan to deviceId , lid org.openhab.binding.appletv.internal.AppleTVThingConfiguration@13e05d97
2025-09-14 09:50:22.350 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:50:22.356 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 334642
2025-09-14 09:50:22.358 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, scan]
2025-09-14 09:50:30.857 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device My Music on raspberrypi discovered: ipAddress=192.168.0.136, deviceId=CB4AE6AD56DD6A12, loginId=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:50:30.857 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='CB4AE6AD56DD6A12', name='My Music on raspberrypi', address='192.168.0.136', services=[Service{protocol='dmap', port=3689, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Unknown', operatingSystem='Legacy', version='null', buildNumber='null', mac='null'}}
2025-09-14 09:50:30.858 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=null, loginId=My Music on raspberrypi, modelId=Unknown, vendor=Apple, ipAddress=192.168.0.136, pairingDmap=Mandatory, firmwareVersion=Legacy null, deviceId=CB4AE6AD56DD6A12}
2025-09-14 09:50:30.860 [INFO ] [ding.appletv.internal.AppleTVHandler] - Device Apple TV sypialnia discovered: ipAddress=192.168.0.52, deviceId=12:54:B9:78:AA:8B, loginId=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], services={}
2025-09-14 09:50:30.861 [INFO ] [ding.appletv.internal.AppleTVHandler] - DeviceInfo: ATVDevice{identifier='12:54:B9:78:AA:8B', name='Apple TV sypialnia', address='192.168.0.52', services=[Service{protocol='airplay', port=7000, password=false, pairing=Mandatory, enabled=true}, Service{protocol='companion', port=49153, password=false, pairing=Mandatory, enabled=true}, Service{protocol='raop', port=7000, password=false, pairing=Mandatory, enabled=true}], deviceInfo=DeviceInfo{model='Gen4K', operatingSystem='TvOS', version='18.6', buildNumber='null', mac='12:54:B9:78:AA:8B'}}
2025-09-14 09:50:30.861 [INFO ] [ding.appletv.internal.AppleTVHandler] - Properties: {macAddress=12:54:B9:78:AA:8B, loginId=Apple TV sypialnia, modelId=AppleTV Gen4K, vendor=Apple, pairingRaop=Mandatory, ipAddress=192.168.0.52, pairingAirplay=Mandatory, pairingCompanion=Mandatory, firmwareVersion=TvOS 18.6, deviceId=12:54:B9:78:AA:8B}
2025-09-14 09:50:30.863 [INFO ] [ding.appletv.internal.AppleTVHandler] - Apple-TV discovery completed
2025-09-14 09:50:31.570 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:55:13.431 [WARN ] [e.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: MINI
2025-09-14 09:55:31.571 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
2025-09-14 09:55:42.582 [INFO ] [nding.appletv.internal.PyATV$Scanner] - queueing command: turn_off
2025-09-14 09:55:42.846 [ERROR] [ding.appletv.internal.AppleTVHandler] - ATV command threw exception: Object of type BlockedStateError is not JSON serializable:
Traceback (most recent call last):
File "/var/lib/openhab/appletv-binding/lib/python3.11/site-packages/pyatv/scripts/atvscript.py", line 483, in _run_command
await getattr(atv.power, command)()
File "/var/lib/openhab/appletv-binding/lib/python3.11/site-packages/pyatv/support/shield.py", line 72, in _guard_method
raise BlockedStateError(f"{func.__name__} is blocked")
pyatv.exceptions.BlockedStateError: power is blocked
During handling of the above exception, another exception occurred:
File "/var/lib/openhab/appletv-binding/lib/python3.11/site-packages/pyatv/scripts/atvscript.py", line 618, in appstart
args.output(await _handle_command(args, abort_sem, storage, loop)),
File "/var/lib/openhab/appletv-binding/lib/python3.11/site-packages/pyatv/scripts/atvscript.py", line 359, in _handle_command
return await _run_command(atv, args, abort_sem, loop)
File "/var/lib/openhab/appletv-binding/lib/python3.11/site-packages/pyatv/scripts/atvscript.py", line 526, in _run_command
stdout_write_nb(args.output(output(False, values={"exception": e})))
File "/usr/lib/python3.11/json/__init__.py", line 231, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python3.11/json/encoder.py", line 200, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python3.11/json/encoder.py", line 258, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python3.11/json/encoder.py", line 180, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
TypeError: Object of type BlockedStateError is not JSON serializable
2025-09-14 09:55:44.249 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Command process=276065 exited.
2025-09-14 09:55:44.250 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Process 276065 exists.
2025-09-14 09:55:44.257 [WARN ] [nding.appletv.internal.PyATV$Scanner] - PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:55:44.257 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Started process 334960
2025-09-14 09:55:44.258 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Process 334960 isRunning=true
2025-09-14 09:55:44.258 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Running /var/lib/openhab/tmp/appletv-binding/bin/atvscript -i 1254B978AA8B --raop-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:8cff57ed265b04c4e75b199cc838dadb7b78082dd4a9007db3de114cfd928ba9:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39663839643535322d313664642d343237392d393833382d633335336633343833303462 --airplay-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:656c0495d7b5aea9ff5120843876f05cc81e87d9b6a69991c9a1be57d3350c17:31313534423937382d414138422d343837412d413932372d433845383644423635314536:30396333396264642d643433332d343238372d396431382d366162386234303935393832 --companion-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:a720ba105ea66c46f6905934d18a582bcd2e734dec03843a4cdf61046d5b8b2f:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39643732643133352d623062302d346239322d613434322d343435306437323831386238 command_loop
2025-09-14 09:55:44.752 [INFO ] [nding.appletv.internal.PyATV$Scanner] - queueing command: turn_on
2025-09-14 09:55:47.532 [WARN ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Error occurred in '/var/lib/openhab/tmp/appletv-binding/bin/atvscript -i 1254B978AA8B --raop-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:8cff57ed265b04c4e75b199cc838dadb7b78082dd4a9007db3de114cfd928ba9:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39663839643535322d313664642d343237392d393833382d633335336633343833303462 --airplay-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:656c0495d7b5aea9ff5120843876f05cc81e87d9b6a69991c9a1be57d3350c17:31313534423937382d414138422d343837412d413932372d433845383644423635314536:30396333396264642d643433332d343238372d396431382d366162386234303935393832 --companion-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:a720ba105ea66c46f6905934d18a582bcd2e734dec03843a4cdf61046d5b8b2f:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39643732643133352d623062302d346239322d613434322d343435306437323831386238 command_loop'
com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Unexpected value at line 1 column 30 path $
See https://github.com/google/gson/blob/main/Troubleshooting.md#malformed-json
at com.google.gson.JsonStreamParser.hasNext(JsonStreamParser.java:108) ~[?:?]
at org.openhab.binding.appletv.internal.PyATV$Scanner.executeCommandLineAndParseJson(PyATV.java:515) ~[?:?]
at org.openhab.binding.appletv.internal.PyATV$Scanner.runReaderThread(PyATV.java:356) ~[?:?]
at java.lang.Thread.run(Thread.java:1583) [?:?]
Caused by: com.google.gson.stream.MalformedJsonException: Unexpected value at line 1 column 30 path $
at com.google.gson.stream.JsonReader.syntaxError(JsonReader.java:1817) ~[?:?]
at com.google.gson.stream.JsonReader.doPeek(JsonReader.java:696) ~[?:?]
at com.google.gson.stream.JsonReader.peek(JsonReader.java:547) ~[?:?]
at com.google.gson.JsonStreamParser.hasNext(JsonStreamParser.java:106) ~[?:?]
... 3 more
2025-09-14 09:55:47.539 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Command process=334960 exited.
2025-09-14 09:55:47.539 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Process 334960 exists.
2025-09-14 09:55:47.540 [INFO ] [nding.appletv.internal.PyATV$Scanner] - destroying process 334960 forcibly.
2025-09-14 09:55:47.542 [INFO ] [ding.appletv.internal.AppleTVHandler] - Received word that device went offline.
2025-09-14 09:55:47.542 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: stop()
2025-09-14 09:55:47.543 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Attempt to read command queue was interrupted.
2025-09-14 09:55:47.544 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: exiting command poller
2025-09-14 09:55:47.545 [ERROR] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Exception thrown in runWriterThread
java.lang.NullPointerException: Cannot invoke "java.lang.Process.pid()" because "this.process" is null
at org.openhab.binding.appletv.internal.PyATV$Scanner.runWriterThread(PyATV.java:381) ~[?:?]
2025-09-14 09:55:47.548 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Scanner not running, will not attempt to stop.
2025-09-14 09:55:47.549 [INFO ] [nding.appletv.internal.PyATV$Scanner] - returning because !keepRunning
2025-09-14 09:55:47.549 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:55:47.564 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 334966
2025-09-14 09:55:47.566 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvremote, -i, 1254B978AA8B, --raop-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:8cff57ed265b04c4e75b199cc838dadb7b78082dd4a9007db3de114cfd928ba9:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39663839643535322d313664642d343237392d393833382d633335336633343833303462, --airplay-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:656c0495d7b5aea9ff5120843876f05cc81e87d9b6a69991c9a1be57d3350c17:31313534423937382d414138422d343837412d413932372d433845383644423635314536:30396333396264642d643433332d343238372d396431382d366162386234303935393832, --companion-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:a720ba105ea66c46f6905934d18a582bcd2e734dec03843a4cdf61046d5b8b2f:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39643732643133352d623062302d346239322d613434322d343435306437323831386238, mac]
2025-09-14 09:55:50.965 [INFO ] [ding.appletv.internal.AppleTVHandler] - Pairing Verified: 12:54:B9:78:AA:8B
2025-09-14 09:55:50.966 [WARN ] [enhab.binding.appletv.internal.PyATV] - PaTH: /var/lib/openhab/tmp/appletv-binding/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:55:50.971 [INFO ] [enhab.binding.appletv.internal.PyATV] - Started process 334972
2025-09-14 09:55:50.971 [INFO ] [enhab.binding.appletv.internal.PyATV] - Running [/var/lib/openhab/tmp/appletv-binding/bin/atvscript, -i, 1254B978AA8B, --raop-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:8cff57ed265b04c4e75b199cc838dadb7b78082dd4a9007db3de114cfd928ba9:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39663839643535322d313664642d343237392d393833382d633335336633343833303462, --airplay-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:656c0495d7b5aea9ff5120843876f05cc81e87d9b6a69991c9a1be57d3350c17:31313534423937382d414138422d343837412d413932372d433845383644423635314536:30396333396264642d643433332d343238372d396431382d366162386234303935393832, --companion-credentials, 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:a720ba105ea66c46f6905934d18a582bcd2e734dec03843a4cdf61046d5b8b2f:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39643732643133352d623062302d346239322d613434322d343435306437323831386238, all_features]
2025-09-14 09:55:53.515 [INFO ] [ding.appletv.internal.AppleTVHandler] - Features: Features{features=[FeatureInfo{name='Up', state=Available, options={}}, FeatureInfo{name='Down', state=Available, options={}}, FeatureInfo{name='Left', state=Available, options={}}, FeatureInfo{name='Right', state=Available, options={}}, FeatureInfo{name='Play', state=Unavailable, options={}}, FeatureInfo{name='PlayPause', state=Unavailable, options={}}, FeatureInfo{name='Pause', state=Unavailable, options={}}, FeatureInfo{name='Stop', state=Unavailable, options={}}, FeatureInfo{name='Next', state=Unavailable, options={}}, FeatureInfo{name='Previous', state=Unavailable, options={}}, FeatureInfo{name='Select', state=Available, options={}}, FeatureInfo{name='Menu', state=Available, options={}}, FeatureInfo{name='VolumeUp', state=Available, options={}}, FeatureInfo{name='VolumeDown', state=Available, options={}}, FeatureInfo{name='Home', state=Available, options={}}, FeatureInfo{name='HomeHold', state=Available, options={}}, FeatureInfo{name='TopMenu', state=Available, options={}}, FeatureInfo{name='SkipForward', state=Unavailable, options={}}, FeatureInfo{name='SkipBackward', state=Unavailable, options={}}, FeatureInfo{name='SetPosition', state=Unavailable, options={}}, FeatureInfo{name='SetShuffle', state=Unavailable, options={}}, FeatureInfo{name='SetRepeat', state=Unavailable, options={}}, FeatureInfo{name='ChannelUp', state=Available, options={}}, FeatureInfo{name='ChannelDown', state=Available, options={}}, FeatureInfo{name='Title', state=Unavailable, options={}}, FeatureInfo{name='Artist', state=Unavailable, options={}}, FeatureInfo{name='Album', state=Unavailable, options={}}, FeatureInfo{name='Genre', state=Unavailable, options={}}, FeatureInfo{name='TotalTime', state=Unavailable, options={}}, FeatureInfo{name='Position', state=Unavailable, options={}}, FeatureInfo{name='Shuffle', state=Unavailable, options={}}, FeatureInfo{name='Repeat', state=Unavailable, options={}}, FeatureInfo{name='SeriesName', state=Unavailable, options={}}, FeatureInfo{name='SeasonNumber', state=Unavailable, options={}}, FeatureInfo{name='EpisodeNumber', state=Unavailable, options={}}, FeatureInfo{name='ContentIdentifier', state=Unavailable, options={}}, FeatureInfo{name='iTunesStoreIdentifier', state=Unavailable, options={}}, FeatureInfo{name='AppList', state=Available, options={}}, FeatureInfo{name='LaunchApp', state=Available, options={}}, FeatureInfo{name='AccountList', state=Available, options={}}, FeatureInfo{name='SwitchAccount', state=Available, options={}}, FeatureInfo{name='Artwork', state=Unavailable, options={}}, FeatureInfo{name='App', state=Unavailable, options={}}, FeatureInfo{name='PushUpdates', state=Available, options={}}, FeatureInfo{name='PlayUrl', state=Available, options={}}, FeatureInfo{name='StreamFile', state=Available, options={}}, FeatureInfo{name='PowerState', state=Available, options={}}, FeatureInfo{name='Screensaver', state=Available, options={}}, FeatureInfo{name='TurnOn', state=Available, options={}}, FeatureInfo{name='TurnOff', state=Available, options={}}, FeatureInfo{name='Volume', state=Unavailable, options={}}, FeatureInfo{name='SetVolume', state=Unavailable, options={}}, FeatureInfo{name='OutputDevices', state=Available, options={}}, FeatureInfo{name='AddOutputDevices', state=Available, options={}}, FeatureInfo{name='RemoveOutputDevices', state=Available, options={}}, FeatureInfo{name='SetOutputDevices', state=Available, options={}}, FeatureInfo{name='TextFocusState', state=Available, options={}}, FeatureInfo{name='TextGet', state=Available, options={}}, FeatureInfo{name='TextClear', state=Available, options={}}, FeatureInfo{name='TextAppend', state=Available, options={}}, FeatureInfo{name='TextSet', state=Available, options={}}, FeatureInfo{name='Swipe', state=Available, options={}}, FeatureInfo{name='Action', state=Available, options={}}, FeatureInfo{name='Click', state=Available, options={}}]}
2025-09-14 09:55:53.516 [INFO ] [ding.appletv.internal.AppleTVHandler] - Command Scanner: null
2025-09-14 09:55:53.517 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: start()
2025-09-14 09:55:53.517 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: starting handler threads
2025-09-14 09:55:53.518 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Scanner starting
2025-09-14 09:55:53.518 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Commander starting
2025-09-14 09:55:53.519 [INFO ] [nding.appletv.internal.PyATV$Scanner] - aieee
2025-09-14 09:55:53.519 [WARN ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop process not running. waiting 500ms. Scanner{name='AppleTVCommandLoop', process=null, isStarted=true, expectedCommandLine='null'}
2025-09-14 09:55:53.523 [WARN ] [nding.appletv.internal.PyATV$Scanner] - PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
2025-09-14 09:55:53.524 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Started process 334981
2025-09-14 09:55:53.524 [INFO ] [nding.appletv.internal.PyATV$Scanner] - Process 334981 isRunning=true
2025-09-14 09:55:53.524 [INFO ] [nding.appletv.internal.PyATV$Scanner] - AppleTVCommandLoop: Running /var/lib/openhab/tmp/appletv-binding/bin/atvscript -i 1254B978AA8B --raop-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:8cff57ed265b04c4e75b199cc838dadb7b78082dd4a9007db3de114cfd928ba9:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39663839643535322d313664642d343237392d393833382d633335336633343833303462 --airplay-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:656c0495d7b5aea9ff5120843876f05cc81e87d9b6a69991c9a1be57d3350c17:31313534423937382d414138422d343837412d413932372d433845383644423635314536:30396333396264642d643433332d343238372d396431382d366162386234303935393832 --companion-credentials 8dcc9a296e6d472c793ddee7e6d8295341266a64447c08c8efa8b10c53aafaf6:a720ba105ea66c46f6905934d18a582bcd2e734dec03843a4cdf61046d5b8b2f:31313534423937382d414138422d343837412d413932372d433845383644423635314536:39643732643133352d623062302d346239322d613434322d343435306437323831386238 command_loop
2025-09-14 10:00:00.520 [DEBUG] [time.internal.engine.DSLScriptEngine] - Script uses context 'irrigation-6'.
2025-09-14 10:00:31.583 [WARN ] [ding.tuya.internal.cloud.TuyaOpenAPI] - Server reported invalid token. This should never happen. Trying to re-login.
