I started with a small prototype more than one year ago, after I figured out how to control Revogi’s Smart Strip without using cloud services or their app, without being dependent on internet access for using it.
I think I’ll create a PR soon, but maybe you have some feedback before
I’m just starting with OpenHAB, with version 3. I have installed your add-on as I have REVOGI sockets (for instance from MaxSmart (Max Hauri) but it’s identical to the one you use except the socket form factor).
You say it is meant for SOW019. Can you please confirm the software version, or if the API is the same as the one described on my article here: MaxSmart/Revogi – Prise multiple automatisable et RestAPI – La vie rêvée d'Akim (it’s in french, but if you scroll down or search for http you will find the API commands I found) ?
I currently have firmware 1.30 and still use app (on iphone and android) version 1.x (1.5.7 on my iphone). I never approved the upgrade as I’m pretty sure it closes the API access and only allow to use the cloud.
Anyway. I get a “An error occurred: Unsupported Media Type” message when I try to add all after scan (discovery worked like a charm). And I wondered if this was related to the model version detection.
Could you give me a lead on where I can edit that and do some testing ?
To be honest I can’t say what firmware version is running there. The app doesn’t work for me unfortunately, and I don’t know a way how to find out the version.
V3 API is used. I wonder if this is the updated API I would get if I let the Max Hauri App 2.0 update my firmware (The app says MaxSmart 2 V3… So … just a guess).
Port 8888 is now used. On my version, it’s still port 80
Command numbers have changed. I see command 20 for switch on/off. So V3 API has not the same command numbers…
What you shared is useful. I’ll give it some thoughts.
I still wonder if I should try to update one of my strips, or if I should get to work on developing a binding of my own. Not sure it worth the effort…
