Just found a solution to integrate the Samsung MultiRoom Speakers using the Exec-Binding and the following Bash-Script.
Would someone be able to make a binding out of it?
Best
Florian
#! /bin/bash
# Author: F. Hatz
# based on 'https://github.com/bacl/WAM_API_DOC'
# start with MultiRoom.sh Speaker-IP UUID OBJECTID [OBJECTID OBJECTID ...] volume
# or with MultiRoom.sh Speaker-IP fav1/fav2/fav3/radio1/radio2/radio3 volume
# or with MultiRoom.sh Speaker-IP play/pause/stop (song: play/pause radio: stop)
# or with MultiRoom.sh Speaker-IP next/previous
# or with MultiRoom.sh Speaker-IP mute on/off
# or with MultiRoom.sh Speaker-IP volume
# or with MultiRoom.sh Speaker-IP show title/id (show information of played song)
# or with MultiRoom.sh Speaker-IP list (show uuid and objectid's of actual playlist)
# or with MultiRoom.sh Speaker-IP presets all/fav1/fav2/fav3/radio1/radio2/radio3
# or with MultiRoom.sh Speaker-IP name (speaker name)
# or with MultiRoom.sh Speaker-IP soundshare (set input to soundshare = TV-connect)
PATH=/sbin:/usr/sbin:/bin:/usr/bin
CURL="/usr/bin/curl"
PORT="55001"
COMMAND=".."
VOLUME=".."
SPEAKER=".."
declare -a OBJECTID
OBJ_NUM=0
VAR_NUM=0
for i in "$@"; do
VAR_NUM=$(($VAR_NUM+1))
if [ $VAR_NUM -eq 1 ] 2>/dev/null ; then
SPEAKER=$i
elif [ $VAR_NUM -eq 2 ] ; then
if [ "$i" -eq "$i" ] 2>/dev/null ; then
COMMAND="volume"
VOLUME=$i
elif [ $(echo ${#i}) -gt 10 ] 2>/dev/null ; then
COMMAND="song"
UUID=$i
else
COMMAND="$i"
fi
elif [ $VAR_NUM -eq $# ] 2>/dev/null ; then
if [ $(echo ${#i}) -lt 10 ] 2>/dev/null ; then
VOLUME="$i"
else
OBJECTID["$OBJ_NUM"]="$i"
OBJ_NUM=$(($OBJ_NUM+1))
fi
else
fi
done
if [ $SPEAKER == ".." ] ; then
echo "Error, ip-adress of speaker must be first argument"
exit 1
fi
if [ "$VOLUME" -eq "$VOLUME" ] 2>/dev/null
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3ESetVolume%3C/name%3E%3Cp%20type=%22dec%22%20name=%22volume%22%20val=%22$VOLUME%22/%3E"
$CURL $MSG -s >/dev/null
fi
case $COMMAND in
stop)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22stop%22/%3E"
pause)
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22pause%22/%3E"
play)
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetPlaybackControl%3C/name%3E%3Cp%20type=%22str%22%20name=%22playbackcontrol%22%20val=%22resume%22/%3E"
next)
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetTrickMode%3C/name%3E%3Cp%20type=%22str%22%20name=%22trickmode%22%20val=%22next%22/%3E"
previous)
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetTrickMode%3C/name%3E%3Cp%20type=%22str%22%20name=%22trickmode%22%20val=%22previous%22/%3E"
mute)
if [ "$VOLUME" == ".." ] 2>/dev/null ; then
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3EGetMute%3C/name%3E"
MUTE=$($CURL $MSG -s)
MUTE=($(echo "$MUTE" | grep -oP "(?<=<mute>)[^<]+"))
if [ $MUTE == "off" ]; then
VOLUME="on"
else
VOLUME="off"
fi
fi
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cpwron%3Eon%3C/pwron%3E%3Cname%3ESetMute%3C/name%3E%3Cp%20type=%22str%22%20name=%22mute%22%20val=%22$VOLUME%22/%3E"
echo "Mute $VOLUME"
fav1)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%221%22/%3E"
echo "Play Favorite 1"
fav2)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%221%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%221%22/%3E"
echo "Play Favorite 2"
fav3)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%222%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%221%22/%3E"
echo "Play Favorite 3"
radio1)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%223%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%220%22/%3E"
echo "Play Radio 1"
radio2)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%224%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%220%22/%3E"
echo "Play Radio 1"
radio3)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3ESetPlayPreset%3C/name%3E%3Cp%20type=%22dec%22%20name=%22presetindex%22%20val=%225%22/%3E%3Cp%20type=%22dec%22%20name=%22presettype%22%20val=%220%22/%3E"
echo "Play Radio 1"
song)
for i in ${!OBJECTID[*]} ; do
ID="${OBJECTID[$i]}"
if [ "$i" -eq 0 ] 2>/dev/null ; then
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3ESetNewPlaylistPlaybackControl%3C%2Fname%3E%3Cp%20type%3D%22dec%22%20name%3D%22selcount%22%20val%3D%221%22%2F%3E%3Cp%20type%3D%22dec%22%20name%3D%22playtime%22%20val%3D%220%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22type%22%20val%3D%22new%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22device_udn%22%20val%3D%22uuid%3A$UUID%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22objectid%22%20val%3D%22$ID%22%2F%3E%3Cp%20type%3D%22cdata%22%20name%3D%22songtitle%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5BSong%201%5D%5D%3E%3C%2Fp%3E%3Cp%20type%3D%22cdata%22%20name%3D%22thumbnail%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5B%5D%5D%3E%3C%2Fp%3E%3Cp%20type%3D%22cdata%22%20name%3D%22artist%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5B%5D%5D%3E%3C%2Fp%3E"
echo "Play Song"
else
SONG_N=$(($i+1))
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3EAddSongsToMultiQueue%3C%2Fname%3E%3Cp%20type%3D%22dec%22%20name%3D%22count%22%20val%3D%221%22%2F%3E%3Cp%20type%3D%22dec%22%20name%3D%22totalcount%22%20val%3D%221%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22position%22%20val%3D%22last%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22device_udn%22%20val%3D%22uuid%3A$UUID%22%2F%3E%3Cp%20type%3D%22str%22%20name%3D%22objectid%22%20val%3D%22$ID%22%2F%3E%3Cp%20type%3D%22cdata%22%20name%3D%22songtitle%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5BSong%20$SONG_N%5D%5D%3E%3C%2Fp%3E%3Cp%20type%3D%22cdata%22%20name%3D%22thumbnail%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5B%5D%5D%3E%3C%2Fp%3E%3Cp%20type%3D%22cdata%22%20name%3D%22artist%22%20val%3D%22empty%22%3E%3C!%5BCDATA%5B%5D%5D%3E%3C%2Fp%3E"
echo "Add Song $SONG_N"
fi
done
volume)
echo "Volume $VOLUME"
show)
IFS_BACK=$IFS
IFS=$'\n'
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3EGetMusicInfo%3C/name%3E"
SONG=$($CURL $MSG -s)
SONG_T=($(echo "$SONG" | grep -oP "(?<=<title>)[^/]+"))
if [ -n "${SONG_T}" ]; then
SONG_T=${SONG_T##*[}
SONG_T=${SONG_T%%]*}
SONG_A=($(echo "$SONG" | grep -oP "(?<=<artist>)[^/]+"))
SONG_A=${SONG_A##*[}
SONG_A=${SONG_A%%]*}
SONG_UUID=($(echo "$SONG" | grep -oP "(?<=<device_udn>)[^<]+"))
SONG_UUID=${SONG_UUID##*:}
SONG_OID=($(echo "$SONG" | grep -oP "(?<=<objectid>)[^/]+"))
SONG_OID=${SONG_OID##*[}
SONG_OID=${SONG_OID%%]*}
if [ $VOLUME == "id" ] ; then
echo "$SONG_UUID $SONG_OID"
exit 1
elif [ $VOLUME == "title" ] ; then
echo "$SONG_T - $SONG_A"
exit 1
else
echo "$SONG_T - $SONG_A (uuid: $SONG_UUID / objectid: $SONG_OID)"
fi
fi
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3EGetRadioInfo%3C/name%3E"
RADIO=$($CURL $MSG -s)
RADIO_T=($(echo "$RADIO" | grep -oP "(?<=<title>)[^<]+"))
if [ -n "${RADIO_T}" ]; then
echo "$RADIO_T"
fi
IFS=$IFS_BACK
presets)
MSG="http://$SPEAKER:$PORT/CPM?cmd=%3Cname%3EGetPresetList%3C/name%3E%3Cp%20type=%22dec%22%20name=%22startindex%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22listcount%22%20val=%22100%22/%3E"
PRESETS=$($CURL $MSG -s)
IFS_BACK=$IFS
IFS=$'\n'
TITLES=($(echo "$PRESETS" | grep -oP "(?<=<title>)[^<]+"))
if [ $VOLUME == "fav1" ]; then
echo "${TITLES[0]}"
elif [ $VOLUME == "fav2" ]; then
echo "${TITLES[1]}"
elif [ $VOLUME == "fav3" ]; then
echo "${TITLES[2]}"
elif [ $VOLUME == "radio1" ]; then
echo "${TITLES[3]}"
elif [ $VOLUME == "radio2" ]; then
echo "${TITLES[4]}"
elif [ $VOLUME == "radio3" ]; then
echo "${TITLES[5]}"
elif [ $VOLUME == "radio4" ]; then
echo "${TITLES[6]}"
else
echo "---------Favorites---------"
for i in ${!TITLES[*]}
do
if [ $i \= 3 ]
echo "---------Radio-------------"
fi
if [ $i \< 3 ] 2>/dev/null
let j=$i+1
echo "Favorite $j: ${TITLES[$i]}"
else
let j=$i-2
echo "Preset $j: ${TITLES[$i]}"
fi
done
fi
IFS=$IFS_BACK
list)
IFS_BACK=$IFS
IFS=$'\n'
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3EGetCurrentMultiQueuelist%3C/name%3E%3Cp%20type=%22dec%22%20name=%22liststartindex%22%20val=%220%22/%3E%3Cp%20type=%22dec%22%20name=%22listcount%22%20val=%22100%22/%3E"
LIST=$($CURL $MSG -s)
UUID=($(echo "$LIST" | grep -oP "(?<=uuid:)[^<]+"))
TITLES=($(echo "$LIST" | grep -oP "(?<=object_id)[^>]+"))
LIST="$UUID"
for i in ${!TITLES[*]} ; do
T=${TITLES[$i]}
T_L=${#T}-3
T=${T:2:T_L}
LIST="$LIST $T"
done
echo "$LIST"
IFS=$IFS_BACK
name)
IFS_BACK=$IFS
IFS=$'\n'
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3EGetSpkName%3C/name%3E"
SPK_NAME=$($CURL $MSG -s)
SPK_NAME=($(echo "$SPK_NAME" | grep -oP "(?<=<spkname>)[^/]+"))
SPK_NAME=${SPK_NAME##*[}
SPK_NAME=${SPK_NAME%%]*}
echo "$SPK_NAME"
IFS=$IFS_BACK
soundshare)
MSG="http://$SPEAKER:$PORT/UIC?cmd=%3Cname%3ESetFunc%3C/name%3E%3Cp%20type=%22str%22%20name=%22function%22%20val=%22soundshare%22/%3E"
echo "Input: TV-Connect"
echo "Usage: Error - $COMMAND" >&2
esac
exit 1
