it’s my first post here, sorry if it’s a duplicate but I didn’t found any solution on the forum.
I have a Yeelight Color Bulb. In the past I connected it via the Yeelight Binding. But then it lost connection after a few days. After a restart, it worked again for some time.
So I try the miio binding.
After installing the binding the inbox is empty. So I tried adding the thing manually.
I have already discoverd the token and my thing configuration looks like this:
Thing miio:basic:light22 "My Light" [ host="192.168.179.87", token="7df328346c38b071076886d3260e2306" ]
But I get this error in the log:
miio:basic:light22’ changed from ONLINE to OFFLINE (CONFIGURATION_ERROR)
Maybe the deviceID is missing, but I have no idea where I can find it.
From the Doc’s:
“Newer devices may not yet be supported. However, many devices share large similarities with existing devices. The binding allows to try/test if your new device is working with database files of older devices as well. For this, first remove your unsupported thing. Manually add a miio:basic thing. Besides the regular configuration (like ip address, token) the modelId needs to be provided. Normally the modelId is populated with the model of your device, however in this case, use the modelId of a similar device. Look at the openhab forum, or the openhab github repository for the modelId of similar devices.”
Try using a similar devices ID or do the following:
