Here is the information requested:
This information was obtained shortly after startup and it was still responding at the time. If normally works a little while, you can activate a switch and see the change “off to on” and “on to off” in the events log. Then after a while you can operate the inputs and nothing appears in the events.log. You can restart openhab and it will work again for awhile.
PS C:\openhab2> c:\openhab2\start.bat
Launching the openHAB runtime...
__ _____ ____
____ ____ ___ ____ / / / / | / __ )
/ __ \/ __ \/ _ \/ __ \/ /_/ / /| | / __ |
/ /_/ / /_/ / __/ / / / __ / ___ |/ /_/ /
\____/ .___/\___/_/ /_/_/ /_/_/ |_/_____/
/_/ 2.5.6
Release Build
Hit '<tab>' for a list of available commands
and '[cmd] --help' for help on a specific command.
Hit '<ctrl-d>' or type 'system:shutdown' or 'logout' to shutdown openHAB.
openhab> feature:list -s |grep openhab-transport-serial
openhab-transport-serial │ 2.5.0 │ x │ Started │ distro-2.5.6 │ Serial Transport
openhab>
openhab> bundle:list -s |grep pool
213 │ Resolved │ 80 │ 2.4.3 │ org.apache.commons.pool2
openhab>
openhab> bundle:list -s |grep modbus
203 │ Active │ 80 │ 2.5.8.202008150359 │ org.openhab.io.transport.modbus
204 │ Active │ 80 │ 2.5.8.202008150359 │ org.openhab.binding.modbus
openhab>
openhab>
http://localhost:8080/rest/things
[{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Regular Poll","bridgeUID":"modbus:tcp:HVAC","configuration":{"start":32768,"length":1,"refresh":200,"maxTries":3,"cacheMillis":50,"type":"holding"},"properties":{},"UID":"modbus:poller:HVAC:hvacpoll","thingTypeUID":"modbus:poller","channels":[]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"int16","readTransform":"default","writeTransform":"default","readStart":"32768","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:reg32768","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:reg32768:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.0","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di0","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i0"],"uid":"modbus:data:HVAC:hvacpoll:di0:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di0:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus TCP Slave","configuration":{"timeBetweenTransactionsMillis":60,"connectMaxTries":1,"reconnectAfterMillis":0,"port":502,"timeBetweenReconnectMillis":0,"host":"192.168.1.111","connectTimeoutMillis":10000,"id":1,"enableDiscovery":false},"properties":{},"UID":"modbus:tcp:HVAC","thingTypeUID":"modbus:tcp","channels":[]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.2","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di2","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i2"],"uid":"modbus:data:HVAC:hvacpoll:di2:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di2:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.1","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di1","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i1"],"uid":"modbus:data:HVAC:hvacpoll:di1:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di1:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.10","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di10","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i10"],"uid":"modbus:data:HVAC:hvacpoll:di10:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di10:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.11","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di11","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i11"],"uid":"modbus:data:HVAC:hvacpoll:di11:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di11:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.4","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di4","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i4"],"uid":"modbus:data:HVAC:hvacpoll:di4:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:lastReadError","id":"lastReadError","channelTypeUID":"modbus:last-erroring-read-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Read","description":"Date of last read error","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:lastWriteSuccess","id":"lastWriteSuccess","channelTypeUID":"modbus:last-successful-write-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Write","description":"Date of last write","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di4:lastWriteError","id":"lastWriteError","channelTypeUID":"modbus:last-erroring-write-type","itemType":"DateTime","kind":"STATE","label":"Last Erroring Write","description":"Date of last write error","defaultTags":[],"properties":{},"configuration":{}}]},{"statusInfo":{"status":"ONLINE","statusDetail":"NONE"},"editable":false,"label":"Modbus Data","bridgeUID":"modbus:poller:HVAC:hvacpoll","configuration":{"readValueType":"bit","readTransform":"default","writeTransform":"default","readStart":"32768.3","updateUnchangedValuesEveryMillis":1000,"writeMultipleEvenWithSingleRegisterOrCoil":false,"writeMaxTries":3},"properties":{},"UID":"modbus:data:HVAC:hvacpoll:di3","thingTypeUID":"modbus:data","channels":[{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:number","id":"number","channelTypeUID":"modbus:number-type","itemType":"Number","kind":"STATE","label":"Value as Number","description":"Number item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":["Turck_i3"],"uid":"modbus:data:HVAC:hvacpoll:di3:switch","id":"switch","channelTypeUID":"modbus:switch-type","itemType":"Switch","kind":"STATE","label":"Value as Switch","description":"Switch item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:contact","id":"contact","channelTypeUID":"modbus:contact-type","itemType":"Contact","kind":"STATE","label":"Value as Contact","description":"Contact item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:dimmer","id":"dimmer","channelTypeUID":"modbus:dimmer-type","itemType":"Dimmer","kind":"STATE","label":"Value as Dimmer","description":"Dimmer item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:datetime","id":"datetime","channelTypeUID":"modbus:datetime-type","itemType":"DateTime","kind":"STATE","label":"Value as DateTime","description":"DateTime item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:string","id":"string","channelTypeUID":"modbus:string-type","itemType":"String","kind":"STATE","label":"Value as String","description":"String item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:rollershutter","id":"rollershutter","channelTypeUID":"modbus:rollershutter-type","itemType":"Rollershutter","kind":"STATE","label":"Value as Rollershutter","description":"Rollershutter item channel","defaultTags":[],"properties":{},"configuration":{}},{"linkedItems":[],"uid":"modbus:data:HVAC:hvacpoll:di3:lastReadSuccess","id":"lastReadSuccess","channelTypeUID":"modbus:last-successful-read-type","itemType":"DateTime","kind":"STATE","label":"Last Successful Read","description":"Date of last read","defaultTags":[],"properties":{},"configuration":{}},
The rest of the result from “http://localhost:8080/rest/things” is in the next post.
