SMA error 11.59 smal.pcapng.txt (69.9 KB) I believe I have the same problem. I’m using OH2 with binding-modbus - 2.5.2. I looked at the protocol (mirror port on my switch) and see many problems and in attached packet capture you see around 11.59 hours that the data exchange even stops and only re-transmission continue. Remove the .txt extension.
I use the following configuration
Bridge modbus:tcp:tripower “SMA Sunny Tripower 5000TL-20” @ “Zolder” [ host=“192.168.100.85”, port=502, id=3, connectMaxTries=3, reconnectAfterMillis=60000, connectTimeoutMillis=3000] {
Bridge poller SMA_Poller_Totaal "SMA_Poller_Totaal" [ start=30531, length=10, refresh=5000, type="holding" ] {
Thing data SMA_Totaal "SMA_Input_Totaal" [ readStart="30531", readValueType="uint32", readTransform="JS(divide1000.js)"]
Thing data SMA_Vandaag "SMA_Input_Vandaag" [ readStart="30535", readValueType="uint32", readTransform="JS(smalimit.js)"]
Bridge poller SMA_Poller_Huidig "SMA_Poller_Huidig" [ start=30775, length=8, refresh=5000, type="holding" ] {
Thing data SMA_Huidig "SMA_Input_Huidig" [ readStart="30775", readValueType="int32", readTransform="JS(smalimit.js)"]
In the logfile I see
2020-09-12 11:17:00.916 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 2/3 error: connect timed out. Connection TCPMasterConnection@6060e114[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:03.979 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 3/3 error: connect timed out. Connection TCPMasterConnection@6060e114[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:03.979 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - re-connect reached max tries 3, throwing last error: connect timed out. Connection TCPMasterConnection@6060e114[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:03.980 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - Error connecting connection TCPMasterConnection@6060e114[socket=Socket[unconnected]] for endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]: connect timed out
2020-09-12 11:17:03.980 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Could not connect to endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502] – aborting request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@408c60ad[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30531,length=10,maxTries=3] [operation ID e43abc95-d803-4a0a-92ad-ef1462dbe5ae]
2020-09-12 11:17:03.981 [ERROR] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:tripower:SMA_Poller_Totaal:SMA_Totaal ‘SMA_Input_Totaal’ had ModbusConnectionException error on read: ModbusConnectionException(Error connecting to endpoint=ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502])
2020-09-12 11:17:03.981 [ERROR] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:tripower:SMA_Poller_Totaal:SMA_Vandaag ‘SMA_Input_Vandaag’ had ModbusConnectionException error on read: ModbusConnectionException(Error connecting to endpoint=ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502])
2020-09-12 11:17:06.983 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: connect timed out. Connection TCPMasterConnection@592f47e9[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:10.047 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 2/3 error: connect timed out. Connection TCPMasterConnection@592f47e9[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:13.111 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 3/3 error: connect timed out. Connection TCPMasterConnection@592f47e9[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:13.111 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - re-connect reached max tries 3, throwing last error: connect timed out. Connection TCPMasterConnection@592f47e9[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:13.112 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - Error connecting connection TCPMasterConnection@592f47e9[socket=Socket[unconnected]] for endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]: connect timed out
2020-09-12 11:17:13.112 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Could not connect to endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502] – aborting request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@11ded93c[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=8,maxTries=3] [operation ID 6d4254f9-2c01-4e2d-98db-6285714ea7a2]
2020-09-12 11:17:13.113 [ERROR] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:tripower:SMA_Poller_Huidig:SMA_Huidig ‘SMA_Input_Huidig’ had ModbusConnectionException error on read: ModbusConnectionException(Error connecting to endpoint=ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502])
2020-09-12 11:17:16.116 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 1/3 error: connect timed out. Connection TCPMasterConnection@782c38b0[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:19.178 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 2/3 error: connect timed out. Connection TCPMasterConnection@782c38b0[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:22.242 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - connect try 3/3 error: connect timed out. Connection TCPMasterConnection@782c38b0[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2020-09-12 11:17:22.243 [ERROR] [ing.ModbusSlaveConnectionFactoryImpl] - re-connect reached max tries 3, throwing last error: connect timed out. Connection TCPMasterConnection@782c38b0[socket=Socket[unconnected]]. Endpoint ModbusTCPSlaveEndpoint@20a39fe2[address=192.168.100.85,port=502]
2
