Very interesting, and hope that we can somehow get the Echo to also use a custom Skill without having to say the ‘Skill’ name first, and do more than just ON/OFF/DIM like the Amazon Echo HA Bridge seemingly offers! Please let me know if you uncover any other details on this!
Coming down home stretch with a public release of my custom Alexa-HA skill! It might happen later tonight baring any unforeseen complications Stay tuned…
@mkent - thanks. This is interesting; at it seems Echo is getting a little more lax in how you issue the Hue bridge commands over time. I’ve read elsewhere that if you create a group which includes ‘THE’, then ‘Open THE garage door’ may work for you as well…
If you’d like to do more sophisticated things, like checking the current status of your garage door through the Echo, be sure to check out our Skill. Once configured, it takes care of all different speech utterances for you automatically, which you can see in the sample-utterances.
@mkent@d0t Well I will reiterate that from day one setting up my echobridge I have been able to say any of the combinations, Alexa, OPEN the garage door, etc.
Have you guys done the speech recognition excercizes to better acclimate your voice to the echo? I know I did that initially, this was like 6-8 months ago I think. OPEN/CLOSE had always worked for ON/OFF for me.
I think it’s interesting that we are seeing some different results.
Since I’ve seen several saying that it’s not possible to make Alexa speak, I just wanted to point out that Bluetooth on the server (and enough proximity to you Echo) is all you need. I have a Bluetooth dongle on my server (for presence detection purposes), and just tried making Alexa speak - and it worked perfectly fine. Unfortunately it’s not the same voice though.
Patrik,
I would like to set up OpenHAB to be able to speak over my Amazon Echo also. Could you please tell me how you set it up? I run OpenHAB on a raspberry pi 3 which has Bluetooth built in.
Put the Echo within Bluetooth reach of the server (or vice versa).
Pair the two (use the Alexa app), and make sure that the Bluetooth Audio is the default sound output.
Install a local TTS on Raspberry. My OH is on Windows, so I use the command line version of Balabolka.
Use executeCommandLine in a rule to run the TTS engine with the desired text.
I guess you could also use a cloud TTS for #3 (using curl and your favorite MP3 player) as long as you can get the Raspberry to play the sound to the Bluetooth speaker.
Tip: If you use the Alexa Echo Bridge REST interface (or similar) for Alexa to communicate with OpenHAB, you will need to add 2-3 seconds of sleep before playing the response sound. Otherwise the Alexa “OK” will silence whatever output you want her to say.
