I’ve tested ON/OFF command on the Color channel and it works, but each command I’ve got the following error in the openhab.log :
2019-01-18 18:01:51.361 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler@35a8b80c': Failed to send OpenAPI request: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: bad response on HttpConnectionOverHTTP@1bfaf522(l:/192.168.0.100:36630 <-> r:/192.168.0.106:16021,closed=false)=>HttpChannelOverHTTP@48a112d5(exchange=HttpExchange@484f14b req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@de2b60e(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2b0df80b{s=START}],recv=HttpReceiverOverHTTP@6bfa6005(rsp=IDLE,failure=null)[HttpParser{s=CLOSE,0 of -1}]]<-SocketChannelEndPoint@48d7ca98{/192.168.0.106:16021<->/192.168.0.100:36630,OPEN,fill=-,flush=-,to=1/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@1bfaf522(l:/192.168.0.100:36630 <-> r:/192.168.0.106:16021,closed=false)=>HttpChannelOverHTTP@48a112d5(exchange=HttpExchange@484f14b req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@de2b60e(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2b0df80b{s=START}],recv=HttpReceiverOverHTTP@6bfa6005(rsp=IDLE,failure=null)[HttpParser{s=CLOSE,0 of -1}]]
org.openhab.binding.nanoleaf.internal.NanoleafException: Failed to send OpenAPI request: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: bad response on HttpConnectionOverHTTP@1bfaf522(l:/192.168.0.100:36630 <-> r:/192.168.0.106:16021,closed=false)=>HttpChannelOverHTTP@48a112d5(exchange=HttpExchange@484f14b req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@de2b60e(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2b0df80b{s=START}],recv=HttpReceiverOverHTTP@6bfa6005(rsp=IDLE,failure=null)[HttpParser{s=CLOSE,0 of -1}]]<-SocketChannelEndPoint@48d7ca98{/192.168.0.106:16021<->/192.168.0.100:36630,OPEN,fill=-,flush=-,to=1/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@1bfaf522(l:/192.168.0.100:36630 <-> r:/192.168.0.106:16021,closed=false)=>HttpChannelOverHTTP@48a112d5(exchange=HttpExchange@484f14b req=TERMINATED/null@null res=PENDING/null@null)[send=HttpSenderOverHTTP@de2b60e(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@2b0df80b{s=START}],recv=HttpReceiverOverHTTP@6bfa6005(rsp=IDLE,failure=null)[HttpParser{s=CLOSE,0 of -1}]] at org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler.sendOpenAPIRequest(NanoleafHandler.java:417) ~[?:?] at org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler.sendEffectCommand(NanoleafHandler.java:148) ~[?:?] at org.openhab.binding.nanoleaf.internal.handler.NanoleafHandler.handleCommand(NanoleafHandler.java:181) ~[?:?] at sun.reflect.GeneratedMethodAccessor114.invoke(Unknown Source) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240] at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240] at com.sun.proxy.$Proxy200.handleCommand(Unknown Source) [275:org.openhab.binding.nanoleaf:2.5.0.201901172300] at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240] at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240] at sun.reflect.GeneratedMethodAccessor113.invoke(Unknown Source) ~[?:?] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:?] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:?] at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240] at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?]
… but it works
Do you plan to add this code to the Brightness channel also or must I change my HABPanel config to send switchs commands to the Color Channel ?
Best regards
