Hi Martin,
I installed your binding for my Nanoleaf Aurora yesterday and came across some interesting an disturbing issue. Binding installs ok, discovery works fine even the authorisation token is granted and included in the thing definition. Afterwards it gets weird: The bridge thing comes online, just to go offline immediately. Even with the bridge thing being marked offline, discovery of the panels works fine, they all show up in Paper UI’s inbox als well in Habmin’s inbox. When going offline, the bridge thing’s status reads “Laufzeitfehler. Siehe openHAB Logdatei für mehr Details.” - “runtime error. please see openhab log for details”. openhab.log contains the following error message, repeating every 15 seconds, which equals to the defined refresh interval:
2019-02-28 08:42:02.074 [WARN ] [al.handler.NanoleafControllerHandler] - Update job failed
at org.openhab.binding.nanoleaf.internal.handler.NanoleafControllerHandler.updateFromControllerInfo(NanoleafControllerHandler.java:472) ~[?:?]
at org.openhab.binding.nanoleaf.internal.handler.NanoleafControllerHandler.runUpdate(NanoleafControllerHandler.java:338) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
2019-02-28 08:45:03.046 [WARN ] [al.handler.NanoleafControllerHandler] - Update job failed
2019-02-28 08:45:18.161 [WARN ] [al.handler.NanoleafControllerHandler] - Update job failed
The Nanoleaf bridge thing is autodiscovered, haven’t defined any items yet. Does this give you any hint on the problem?
Best regards
Kai
