At first deinstall the binding. After this put at first the commons jar into the addons folder. Wait 1-2 minutes and then put the binding into addons folder.
openhab> la -l|grep smarthomej
296 x Active x 80 x 3.2.11.202201210329 x file:/usr/share/openhab/addons/org.smarthomej.commons-3.2.11-20220121.033037-9.jar
297 x Active x 80 x 3.2.11.202201210339 x file:/usr/share/openhab/addons/org.smarthomej.binding.viessmann-3.2.11-20220121.033935-9.jar
Bit still the samer error. Some data can not be parsed correctly…
Exception occurred while initializing handler of thing 'viessmann:device:96afd7d3df:0': Invalid Quantity value: 2098.1 null
I have try the new version but again the same error:
[ERROR] [core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing ‘viessmann:device:9de7da11c2:0’: Invalid Quantity value: 3.8000000000000003 null
java.lang.IllegalArgumentException: Invalid Quantity value: 3.8000000000000003 null
307 │ Active │ 80 │ 3.2.11.202201210329 │ SmartHome/J Add-ons :: Bundles :: Common Components
314 │ Active │ 80 │ 3.2.10.202201212115 │ SmartHome/J Add-ons :: Bundles :: Viessmann Binding
Do i need also new version from the common component??
Nikos
I think there is a feature with unknown unit. So please send me the full log in TRACE mode via PM. I‘ll look for the feature with the unknown unit and fix it asap.
I am receiving
2022-01-22 17:42:26.237 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/usr/share/openhab/addons/org.smarthomej.binding.viessmann-3.2.10-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.smarthomej.binding.viessmann [369]
thanks for your great work on this binding.
I am using the latest version (3.2.11) and i can set the operating mode through openhab. But settings the operating program does not work. Is this support by the api and the binding?
If you sent you me your paypal adress i will invite you for a beer (or what else you like )
