Hi All,
Hope somebody can help me.
I tryiing to connect to my new model 2016 philips TV 49PUS7101/12 but can;t make it word.
In the early models from philips the protocol clearspace on port 1925 does the trick.
But when i try this on my tv i getting a 404 not found error
There is something running on port 1925 but does not do the trick.
I have also opened a topic on the philips forum and a have some respone.
in latest model clearspace is no longer available
i think this is strange because why getting a response on port 1925. -
i need using the Tv remote App(tp vision), this is working on my android device.
did a wireshark trace and this app connects on port 1925 and trace tcp/udp i can;t read.
think is property protocol.
3/ they also sugest i can use the Android TV Remote App from Google.
this is also working, and with some research i found out that this app is using the anymote protocol.
So lots of questions.
Does anybody has a working setup with clearspace with latest philips tv models with android on it?
if yes what are the commands.
Does anybody has another wat that it works and can please send some information.
Is there a binding for anymote?
There is a Github with some java examples? https://github.com/entertailion/Anymote-for-Java
If no can somebody create it?
Please help me out with this annoying issue.
Thanks in advance
Mickel
