Binding to Philips 49PUS7101/12 android TV
Hi, i have a update.
I found on website GitHub - suborb/philips_android_tv: Tools to control Philips 2016 Android TVs 路 GitHub some python code.
With this code the control works :slight_smile:.
First you need to us the command pair to pair the TV with the server, when you do this the TV generates a code that you need to enter on the server.
When that is done, a new user and pass is shown and with this user and pass you can conrol you TV.
Some notes from site
The API is roughly the same as JointSpace (http://jointspace.sourceforge.net/) with the following differences:
-Uses HTTPS over port 1926
-Uses /6/ instead of /1/ as the API path
-All calls have to have digest auth to be successful
-An initial pairing to determine the user/pass is required
-Channel and Source methods aren鈥檛 available
-Channel status and changes are performed using a different protocol that isn鈥檛 described here.
The tool here will do the initial pairing. The credentials can then be used in a standard way (digest) in other tools
Now it would be very nice if the JointSpace Binding from openhab can be adjusted so that it also works in openhab?
Or are there other way to excuste the python script and getting (and reading) the response messages?
Br Mickel
