Binding-wifiled ... only manual installation (to repeat at every reboot)
with OH 2.2 stable the extension ‘binding-wifiled’ is not installed adding:
binding = xxxxx,astro,binding-wifiled
to the
services/addons.cfg
The only way is install the binding is by Papper UI but I need to manual install again the addon at every start/restart.
From the log:
2018-03-27 15:10:20.304 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-binding-wifiled': Error restarting bundles:
    Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="0.10.0.b1"; osgi.identity="org.eclipse.smarthome.model.script.runtime"; singleton:="true" [id=147] STARTED [STARTED]
2018-03-27 15:12:24.937 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.wifiled.handler.WiFiLEDHandler@180bfc6': Could not update status, because callback is missing
java.lang.IllegalStateException: Could not update status, because callback is missing
    at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.updateStatus(BaseThingHandler.java:424) [116:org.eclipse.smarthome.core.thing:0.10.0.b1]
    at org.openhab.binding.wifiled.handler.WiFiLEDHandler.initialize(WiFiLEDHandler.java:76) [229:org.openhab.binding.wifiled:2.2.0]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
    at java.lang.reflect.Method.invoke(Method.java:497) ~[?:?]
    at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [109:org.eclipse.smarthome.core:0.10.0.b1]
    at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [109:org.eclipse.smarthome.core:0.10.0.b1]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
    at java.lang.Thread.run(Thread.java:745) [?:?]
Could you help me?
Regards
Sim
It needs to be wifiled
Oh Sihui,
thank you!
I’m just an idiot… :flushed:
