Hi
I am working on an openhab2 binding. In my case the binding will autodetect the local IP, but it may not always be appropriate, so I need an optional config parameter.
Using a config file would work:
I found out that binding.xml allows me to specify binding config-description, like this:
<config-description>
<parameter name="localIP" type="text">
<label>Local IP</label>
<description>Local IP to bind to. This is optional and only has to be set if the binding is unable to detect it.</description>
</parameter>
</config-description>
Now, is this feasible/recommended? And how would I be able to query the configuration settings in Code?
Regards
Sebastian
