I am having trouble settings up the astro binding. i have the astro binding and astro action installed. i have in my openhab.cfg the lat/lon. Do they need to be ‘.’ or ‘,’ ?
The latitude
astro:latitude=12,345678
The longitude
astro:longitude=12,345678
I get a error in my logfile. "bindingConfig must have a key and a value’"
2016-02-22 14:35:06.435 [ERROR] [i.internal.GenericItemProvider] - Binding configuration of type ‘astro’ of item ‘Zodiac_Sign‘ could not be parsed correctly.
org.openhab.model.item.binding.BindingConfigParseException: A bindingConfig must have a key and a value
at org.openhab.binding.astro.internal.bus.BindingConfigParser.parse(BindingConfigParser.java:64) ~[na:na]
at org.openhab.binding.astro.internal.bus.AstroGenericBindingProvider.processBindingConfiguration(AstroGenericBindingProvider.java:59) ~[na:na]
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:348) [org.openhab.model.item_1.7.0.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:324) [org.openhab.model.item_1.7.0.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:171) [org.openhab.model.item_1.7.0.jar:na]
at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:390) [org.openhab.model.item_1.7.0.jar:na]
at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:159) [org.openhab.model.core_1.7.0.jar:na]
at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:100) [org.openhab.model.core_1.7.0.jar:na]
at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142) [org.openhab.model.core_1.7.0.jar:na]
at org.openhab.model.core.internal.folder.FolderObserver.run(FolderObserver.java:99) [org.openhab.model.core_1.7.0.jar:na]
this is my items file
String Zodiac_Sign “Current zodiac [%s]” (Astro) { astro=“planet=sun,zodiac, property=sign” }
i am running OH 1.7 and the astro 1.7 bindings.
Does anybody know where i go wrong ?
Regards,
Pieter
