I have problem with upgrading openhab2 bindings to proper version.
I’m getting errors:
[ERROR] [org.eclipse.smarthome.binding.astro ] - [org.eclipse.smarthome.binding.astro.internal.discovery.AstroDiscoveryService(17)] The activate method has thrown an exception java.lang.IncompatibleClassChangeError: Expected static field org.eclipse.smarthome.binding.astro.internal.discovery.AstroDiscoveryService.scheduler
[ERROR] [org.openhab.binding.milight ] - [org.openhab.binding.milight.internal.discovery.MilightBridgeDiscovery(24)] The activate method has thrown an exception java.lang.IncompatibleClassChangeError: Expected static field org.openhab.binding.milight.internal.discovery.MilightBridgeDiscovery.scheduler
Based on discussion with @wborn and @BClark09 and @marcelrv version is a problem.
I have no dpkg-new files in /var/lib/openhab
FIrst part of my last bundle list:
15 │ Active │ 80 │ 5.3.1.201602281253 │ mvn:com.eclipsesource.jaxrs/publisher/5.3.1 │ com.eclipsesource.jaxrs.publisher
16 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.core/jackson-annotations/2.4.5 │ com.fasterxml.jackson.core.jackson-annotations
17 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.core/jackson-core/2.4.5 │ com.fasterxml.jackson.core.jackson-core
18 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.core/jackson-databind/2.4.5 │ com.fasterxml.jackson.core.jackson-databind
19 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.dataformat/jackson-dataformat-xml/2.4.5 │ com.fasterxml.jackson.dataformat.jackson-dataformat-xml
20 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.dataformat/jackson-dataformat-yaml/2.4.5 │ com.fasterxml.jackson.dataformat.jackson-dataformat-yaml
21 │ Active │ 80 │ 2.4.5 │ mvn:com.fasterxml.jackson.module/jackson-module-jaxb-annotations/2.4.5 │ com.fasterxml.jackson.module.jackson-module-jaxb-annotations
22 │ Active │ 80 │ 2.7.0 │ mvn:com.google.code.gson/gson/2.7 │ com.google.gson
23 │ Active │ 80 │ 18.0.0 │ mvn:com.google.guava/guava/18.0 │ com.google.guava
24 │ Active │ 80 │ 3.0.0.v201312141243 │ mvn:de.maggu2810.p2redist/com.google.inject/3.0.0.v201312141243 │ com.google.inject
25 │ Active │ 80 │ 1.5.8 │ mvn:io.swagger/swagger-annotations/1.5.8 │ io.swagger.annotations
26 │ Active │ 80 │ 3.19.0.GA │ mvn:org.javassist/javassist/3.19.0-GA │ javassist
28 │ Active │ 80 │ 3.5.2 │ mvn:org.jmdns/jmdns/3.5.2 │ javax.jmdns
30 │ Active │ 80 │ 1.0.0 │ mvn:javax.measure/unit-api/1.0 │ javax.measure.unit-api
32 │ Active │ 80 │ 1.1.0.Final │ mvn:javax.validation/validation-api/1.1.0.Final │ javax.validation.api
33 │ Active │ 80 │ 2.0.1 │ mvn:javax.ws.rs/javax.ws.rs-api/2.0.1 │ javax.ws.rs-api
34 │ Active │ 80 │ 3.2.0.v201101311130 │ mvn:de.maggu2810.p2redist/org.antlr.runtime/3.2.0.v201101311130 │ org.antlr.runtime
35 │ Active │ 80 │ 3.2.1 │ mvn:commons-collections/commons-collections/3.2.1 │ org.apache.commons.collections
36 │ Active │ 80 │ 1.1 │ mvn:org.apache.commons/commons-exec/1.1 │ org.apache.commons.exec
37 │ Active │ 80 │ 2.2.0 │ mvn:commons-io/commons-io/2.2 │ org.apache.commons.io
38 │ Active │ 80 │ 2.6 │ mvn:commons-lang/commons-lang/2.6 │ org.apache.commons.lang
48 │ Active │ 80 │ 4.1.5 │ mvn:org.apache.karaf/org.apache.karaf.event/4.1.5 │ org.apache.karaf.event
67 │ Active │ 80 │ 2.11.0.v20150805-0538 │ mvn:org.eclipse.emf/org.eclipse.emf.common/2.11.0-v20150805-0538 │ org.eclipse.emf.common
68 │ Active │ 80 │ 2.11.1.v20150805-0538 │ mvn:org.eclipse.emf/org.eclipse.emf.ecore/2.11.1-v20150805-0538 │ org.eclipse.emf.ecore
69 │ Active │ 80 │ 2.11.1.v20150805-0538 │ mvn:org.eclipse.emf/org.eclipse.emf.ecore.xmi/2.11.1-v20150805-0538 │ org.eclipse.emf.ecore.xmi
70 │ Active │ 80 │ 3.8.0.v20160509-1230 │ mvn:org.eclipse.platform/org.eclipse.equinox.common/3.8.0 │ org.eclipse.equinox.common
71 │ Active │ 80 │ 3.6.100.v20160223-2218 │ mvn:org.eclipse.platform/org.eclipse.equinox.registry/3.6.100 │ org.eclipse.equinox.registry
76 │ Active │ 80 │ 9.3.15.v20161220 │ mvn:org.eclipse.jetty/jetty-io/9.3.15.v20161220 │ org.eclipse.jetty.io
87 │ Active │ 80 │ 9.3.15.v20161220 │ mvn:org.eclipse.jetty/jetty-util/9.3.15.v20161220 │ org.eclipse.jetty.util
91 │ Active │ 80 │ 9.3.15.v20161220 │ mvn:org.eclipse.jetty.websocket/websocket-api/9.3.15.v20161220 │ org.eclipse.jetty.websocket.api
92 │ Active │ 80 │ 9.3.15.v20161220 │ mvn:org.eclipse.jetty.websocket/websocket-common/9.3.15.v20161220 │ org.eclipse.jetty.websocket.common
94 │ Active │ 80 │ 0.2.1.v20170706-0855 │ mvn:org.eclipse.lsp4j/org.eclipse.lsp4j/0.2.1 │ org.eclipse.lsp4j
95 │ Active │ 80 │ 0.2.1.v20170706-0855 │ mvn:org.eclipse.lsp4j/org.eclipse.lsp4j.jsonrpc/0.2.1 │ org.eclipse.lsp4j.jsonrpc
96 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.core/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.core
97 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.discovery/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.discovery
98 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.discovery.mdns/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.discovery.mdns
99 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.dispatch/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.dispatch
100 │ Active │ 75 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.xml/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.xml
101 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core
102 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.audio/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.audio
103 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.autoupdate/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.autoupdate
104 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.binding.xml/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.binding.xml
105 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.id/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.id
106 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.persistence/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.persistence
107 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.scheduler/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.scheduler
108 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.thing/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.thing
109 │ Active │ 75 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.thing.xml/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.thing.xml
110 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.transform/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.transform
111 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.core/org.eclipse.smarthome.core.voice/0.10.0-SNAPSHOT │ org.eclipse.smarthome.core.voice
112 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.console/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.console
113 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.console.karaf/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.console.karaf
114 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.javasound/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.javasound
115 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.monitor/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.monitor
116 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.net/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.net
117 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest
118 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.core/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.core
119 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.mdns/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.mdns
120 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.optimize/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.optimize
121 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.sitemap/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.sitemap
122 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.sse/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.sse
123 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.rest.voice/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.rest.voice
124 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.transport.mdns/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.transport.mdns
125 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.webaudio/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.webaudio
126 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.core/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.core
127 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.item/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.item
128 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.item.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.item.ide
129 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.item.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.item.runtime
130 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.lsp/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.lsp
131 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.persistence/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.persistence
132 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.persistence.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.persistence.ide
133 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.persistence.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.persistence.runtime
134 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.rule/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.rule
Second part:
135 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.rule.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.rule.ide
136 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.rule.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.rule.runtime
137 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.script/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.script
138 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.script.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.script.ide
139 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.script.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.script.runtime
140 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.sitemap/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.sitemap
141 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.sitemap.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.sitemap.ide
142 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.sitemap.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.sitemap.runtime
143 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.thing/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.thing
144 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.thing.ide/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.thing.ide
145 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.model/org.eclipse.smarthome.model.thing.runtime/0.10.0-SNAPSHOT │ org.eclipse.smarthome.model.thing.runtime
146 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.storage/org.eclipse.smarthome.storage.json/0.10.0-SNAPSHOT │ org.eclipse.smarthome.storage.json
147 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.ui/org.eclipse.smarthome.ui/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui
148 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.ui/org.eclipse.smarthome.ui.icon/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui.icon
149 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.extension.ui.iconset/org.eclipse.smarthome.ui.iconset.classic/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui.iconset.classic
150 │ Active │ 80 │ 2.12.0.v20170518-0757 │ mvn:org.eclipse.xtend/org.eclipse.xtend.lib/2.12.0 │ org.eclipse.xtend.lib
151 │ Active │ 80 │ 2.12.0.v20170518-0757 │ mvn:org.eclipse.xtend/org.eclipse.xtend.lib.macro/2.12.0 │ org.eclipse.xtend.lib.macro
152 │ Active │ 80 │ 2.12.0.v20170518-0959 │ mvn:org.eclipse.xtext/org.eclipse.xtext/2.12.0 │ org.eclipse.xtext
153 │ Active │ 80 │ 2.12.0.v20170519-0752 │ mvn:org.eclipse.xtext/org.eclipse.xtext.common.types/2.12.0 │ org.eclipse.xtext.common.types
154 │ Active │ 80 │ 2.12.0.v20171017-1700 │ mvn:de.maggu2810.thirdparty.org.eclipse.xtext/org.eclipse.xtext.ide/2.12.0.sp2 │ org.eclipse.xtext.ide
155 │ Active │ 80 │ 2.12.0.v20170518-0959 │ mvn:org.eclipse.xtext/org.eclipse.xtext.util/2.12.0 │ org.eclipse.xtext.util
156 │ Active │ 80 │ 2.12.0.v20170519-0752 │ mvn:org.eclipse.xtext/org.eclipse.xtext.xbase/2.12.0 │ org.eclipse.xtext.xbase
157 │ Active │ 80 │ 2.12.0.v20170519-0752 │ mvn:org.eclipse.xtext/org.eclipse.xtext.xbase.ide/2.12.0 │ org.eclipse.xtext.xbase.ide
158 │ Active │ 80 │ 2.12.0.v20170518-0757 │ mvn:org.eclipse.xtext/org.eclipse.xtext.xbase.lib/2.12.0 │ org.eclipse.xtext.xbase.lib
173 │ Active │ 80 │ 2.3.0 │ mvn:org.jupnp/org.jupnp/2.3.0 │ org.jupnp
174 │ Active │ 80 │ 1.9.6 │ mvn:org.jvnet.mimepull/mimepull/1.9.6 │ org.jvnet.mimepull
175 │ Active │ 80 │ 5.0.2 │ mvn:de.maggu2810.requirebundle.fix/org.objectweb.asm/5.0.2 │ org.objectweb.asm
177 │ Active │ 90 │ 2.3.0.201805012049 │ mvn:org.openhab.core/org.openhab.core/2.3.0-SNAPSHOT │ org.openhab.core
178 │ Active │ 80 │ 2.3.0.201805012049 │ mvn:org.openhab.core/org.openhab.core.karaf/2.3.0-SNAPSHOT │ org.openhab.core.karaf
180 │ Resolved │ 80 │ 2.3.0.201805012049 │ mvn:org.openhab.core/org.openhab.io.sound/2.3.0-SNAPSHOT │ org.openhab.io.sound
181 │ Active │ 80 │ 2.3.0.201805012049 │ mvn:org.openhab.core/org.openhab.ui.dashboard/2.3.0-SNAPSHOT │ org.openhab.ui.dashboard
186 │ Active │ 80 │ 3.1.4 │ mvn:org.codehaus.woodstox/stax2-api/3.1.4 │ stax2-api
187 │ Active │ 80 │ 1.0.2 │ mvn:tec.uom.lib/uom-lib-common/1.0.2 │ tec.uom.lib.uom-lib-common
188 │ Active │ 80 │ 1.0.8 │ mvn:tec.uom/uom-se/1.0.8 │ tec.uom.se
189 │ Active │ 80 │ 2.0.0.201703271036 │ file:/usr/share/openhab2/addons/org.openhab.binding.yamahamusiccast_2.0.0.201703271036.jar │ org.openhab.binding.yamahamusiccast
190 │ Active │ 80 │ 1.6.0 │ mvn:commons-codec/commons-codec/1.6 │ org.apache.commons.codec
191 │ Active │ 80 │ 3.2.0 │ mvn:commons-net/commons-net/3.2 │ org.apache.commons.net
192 │ Active │ 80 │ 4.2.3 │ mvn:org.apache.httpcomponents/httpclient-osgi/4.2.3 │ org.apache.httpcomponents.httpclient
193 │ Active │ 80 │ 4.2.3 │ mvn:org.apache.httpcomponents/httpcore-osgi/4.2.3 │ org.apache.httpcomponents.httpcore
194 │ Active │ 80 │ 3.1.0.7 │ mvn:org.apache.servicemix.bundles/org.apache.servicemix.bundles.commons-httpclient/3.1_7 │ org.apache.servicemix.bundles.commons-httpclient
195 │ Active │ 80 │ 2.3.0.201805012049 │ mvn:org.openhab.core/org.openhab.core.compat1x/2.3.0-SNAPSHOT │ org.openhab.core.compat1x
196 │ Active │ 80 │ 1.1.1.201605111122 │ mvn:de.maggu2810.thirdparty.modified.com.eclipsesource.jaxrs/provider-swagger/1.1.1.201605111122 │ com.eclipsesource.jaxrs.provider.swagger
197 │ Active │ 80 │ 2.3.1 │ mvn:com.google.code.gson/gson/2.3.1 │ com.google.gson
198 │ Active │ 80 │ 2.1.0 │ mvn:com.jayway.jsonpath/json-path/2.1.0 │ com.jayway.jsonpath.json-path
199 │ Active │ 80 │ 3.12.0.OH │ mvn:org.openhab/nrjavaserial/3.12.0.OH │ com.neuronrobotics.nrjavaserial
200 │ Active │ 80 │ 1.5.8 │ mvn:io.swagger/swagger-core/1.5.8 │ io.swagger.core
201 │ Active │ 80 │ 1.5.8 │ mvn:io.swagger/swagger-jaxrs/1.5.8 │ io.swagger.jaxrs
202 │ Active │ 80 │ 1.5.8 │ mvn:io.swagger/swagger-models/1.5.8 │ io.swagger.models
203 │ Active │ 80 │ 2.2 │ mvn:net.minidev/json-smart/2.2 │ net.minidev.json-smart
204 │ Active │ 80 │ 3.4.0 │ mvn:org.apache.commons/commons-lang3/3.4 │ org.apache.commons.lang3
205 │ Active │ 80 │ 9.3.15.v20161220 │ mvn:org.eclipse.jetty.websocket/websocket-client/9.3.15.v20161220 │ org.eclipse.jetty.websocket.client
207 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.discovery.upnp/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.discovery.upnp
208 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.discovery.usbserial/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.discovery.usbserial
209 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.discovery.usbserial.linuxsysfs/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.discovery.usbserial.linuxsysfs
210 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.config/org.eclipse.smarthome.config.serial/0.10.0-SNAPSHOT │ org.eclipse.smarthome.config.serial
211 │ Active │ 80 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.extensionservice/org.eclipse.smarthome.extensionservice.marketplace/0.10.0-SNAPSHOT │ org.eclipse.smarthome.extensionservice.marketplace
212 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.transport.serial/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.transport.serial
213 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.transport.serial.rxtx/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.transport.serial.rxtx
214 │ Active │ 80 │ 0.10.0.201804271558 │ mvn:org.eclipse.smarthome.io/org.eclipse.smarthome.io.transport.upnp/0.10.0-SNAPSHOT │ org.eclipse.smarthome.io.transport.upnp
215 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.exec/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.exec
216 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.javascript/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.javascript
217 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.jsonpath/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.jsonpath
218 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.map/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.map
219 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.regex/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.regex
220 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.scale/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.scale
221 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.xpath/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.xpath
222 │ Active │ 75 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.transform/org.eclipse.smarthome.transform.xslt/0.10.0-SNAPSHOT │ org.eclipse.smarthome.transform.xslt
223 │ Active │ 80 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.extension.ui/org.eclipse.smarthome.ui.basic/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui.basic
224 │ Active │ 80 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.extension.ui/org.eclipse.smarthome.ui.classic/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui.classic
225 │ Active │ 80 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.extension.ui/org.eclipse.smarthome.ui.paper/0.10.0-SNAPSHOT │ org.eclipse.smarthome.ui.paper
226 │ Active │ 80 │ 1.12.0.201801040210 │ mvn:org.openhab.action/org.openhab.action.mail/1.12.0-SNAPSHOT │ org.openhab.action.mail
227 │ Active │ 80 │ 1.12.0.201801040210 │ mvn:org.openhab.action/org.openhab.action.xmpp/1.12.0-SNAPSHOT │ org.openhab.action.xmpp
228 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.exec/2.3.0-SNAPSHOT │ org.openhab.binding.exec
229 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.kodi/2.3.0-SNAPSHOT │ org.openhab.binding.kodi
230 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.mihome/2.3.0-SNAPSHOT │ org.openhab.binding.mihome
231 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.milight/2.3.0-SNAPSHOT │ org.openhab.binding.milight
232 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.samsungtv/2.3.0-SNAPSHOT │ org.openhab.binding.samsungtv
233 │ Active │ 80 │ 1.12.0.201801040210 │ mvn:org.openhab.binding/org.openhab.binding.weather/1.12.0-SNAPSHOT │ org.openhab.binding.weather
234 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.binding/org.openhab.binding.zwave/2.3.0-SNAPSHOT │ org.openhab.binding.zwave
235 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.core/org.openhab.io.rest.docs/2.3.0-SNAPSHOT │ org.openhab.io.rest.docs
236 │ Active │ 80 │ 1.12.0.201801040210 │ mvn:org.openhab.persistence/org.openhab.persistence.mapdb/1.12.0-SNAPSHOT │ org.openhab.persistence.mapdb
237 │ Active │ 80 │ 1.12.0.201801040210 │ mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/1.12.0-SNAPSHOT │ org.openhab.persistence.rrd4j
238 │ Resolved │ 75 │ 2.3.0.201801032157 │ mvn:org.openhab.core/org.openhab.ui.basicui/2.3.0-SNAPSHOT │ org.openhab.ui.basicui
239 │ Resolved │ 75 │ 2.3.0.201801032157 │ mvn:org.openhab.core/org.openhab.ui.classicui/2.3.0-SNAPSHOT │ org.openhab.ui.classicui
240 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.ui/org.openhab.ui.habmin/2.3.0-SNAPSHOT │ org.openhab.ui.habmin
241 │ Active │ 80 │ 2.3.0.201801032157 │ mvn:org.openhab.ui/org.openhab.ui.habpanel/2.3.0-SNAPSHOT │ org.openhab.ui.habpanel
242 │ Resolved │ 75 │ 2.3.0.201801032157 │ mvn:org.openhab.core/org.openhab.ui.paperui/2.3.0-SNAPSHOT │ org.openhab.ui.paperui
243 │ Active │ 80 │ 0.9.10.v20160429-1435 │ mvn:de.maggu2810.thirdparty.modified.org.reflections/reflections/0.9.10.v20160429-1435 │ reflections
244 │ Active │ 80 │ 1.5.8.v20160511-1038 │ mvn:de.maggu2810.thirdparty.modified.io.swagger/swagger-jersey2-jaxrs/1.5.8.v20160511-1038 │ swagger-jersey2-jaxrs
245 │ Active │ 80 │ 0.10.0.201712141004 │ mvn:org.eclipse.smarthome.binding/org.eclipse.smarthome.binding.astro/0.10.0-SNAPSHOT │ org.eclipse.smarthome.binding.astro
246 │ Active │ 80 │ 1.1.4 │ https://bintray.com/sputnikdev/org.eclipse.smarthome.binding.bluetooth/download_file?file_path=org.eclipse.smarthome.binding.bluetooth-1.1.4.jar │ org.sputnikdev.org.eclipse.smarthome.binding.bluetooth
247 │ Active │ 80 │ 1.1.1 │ https://bintray.com/sputnikdev/org.eclipse.smarthome.binding.bluetooth/download_file?file_path=org.eclipse.smarthome.binding.bluetooth.transport.tinyb-1.1.1.jar │ org.sputnikdev.org.eclipse.smarthome.binding.bluetooth.transport.tinyb
248 │ Active │ 80 │ 2.3.0.201803300959 │ https://openhab.jfrog.io/openhab/libs-pullrequest-local/org/openhab/binding/org.openhab.binding.miio/2.3.0-SNAPSHOT/org.openhab.binding.miio-2.3.0-SNAPSHOT.jar │ org.openhab.binding.miio
Benjy
(Ben Clark)
May 2, 2018, 2:27pm
#4
Hi @orzechszek , are you on the latest snapshot (built this morning)?
If not would you be able to perform the following commands to delete temporary files:
sudo systemctl stop openhab2
sudo rm -rf /var/lib/openhab2/cache
sudo rm -rf /var/lib/openhab2/tmp
sudo rm -rf /var/lib/openhab2/kar
sudo systemctl start openhab2
Would you then be able to provide us with a log on any new errors and warnings?
It seems that kar/* removing helps ! Errors with milight and astro stopped occuring, Thanks!
Only error discussed with @marcel_verpaalen appear - even binding uninstalling and installing didn’t help.
I have one more question: why I have to install some bindings every upgrade? In list I see something like:
Can I install it permanently?
ssvenn
(ssvenn)
May 2, 2018, 5:00pm
#6
I had problems after updating my installation too, even with the 2.3.0~20180501231708-1 snapshot packages. None of my bindings would initialise properly.
Removing those temp files fixed it though!
It would be really useful if openHAB had some internal counters for errors per binding to show in the paperUI bindings list, send to persistence services, build rules around and so on. I’m having trouble keeping track of what works better or worse between each snapshot version right now
wborn
(Wouter Born)
May 2, 2018, 7:01pm
#7
Benjy:
When you install openhab2-addons and then uninstall it while openHAB is not running the content of the KAR file remains available in /var/lib/openhab2/kar/
. So such a scenario may be the root cause to @orzechszek ’s issue.
Shouldn’t a postrm
script be added to the deb/yum files to make sure the unpacked content is removed @Benjy ?
The whole KAR dir could also be cleaned in the preinst of the openhab package. The KAR files in the /addons
dir would then be unpacked again when openHAB is started.
What with :
Benjy
(Ben Clark)
May 2, 2018, 10:19pm
#9
openhab-distro/#691 made it so that the kar folder now sits inside userdata/tmp
folder. So this now properly cleared on each openhab2
package upgrade. But you’re right in thinking that a postrm
script for the openhab*addons should be added to do this too.
I’m sorry to say I don’t know what’s happening here. Is this a binding installed from the Eclipse Marketplace?
