I have OH2 running on Raspberry Pi with many bindings installed through PaperUI, but now when I am trying to install Z-wave or Astro binding, it doesn’t get installed and I see the following error in openhab logs:
2017-04-14 07:07:26.291 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-04-14 07:07:26.370 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxx, base URL = http://localhost:8080)
2017-04-14 07:07:27.723 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxxx, base URL = http://localhost:8080)
2017-04-14 07:07:34.927 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2017-04-14 07:07:35.369 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2017-04-14 07:07:35.417 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxx, base URL = http://localhost:8080)
2017-04-14 07:07:38.489 [ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
org.osgi.framework.BundleException: Exception in org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start() of bundle org.eclipse.smarthome.io.rest.sse.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.doStart(Module.java:571)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.Module.start(Module.java:439)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:717)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:491)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:437)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:955)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1336)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
Caused by: java.lang.LinkageError: ClassCastException: attempting to castbundleresource://22.fwk8928021/javax/ws/rs/ext/RuntimeDelegate.class to bundleresource://22.fwk8928021/javax/ws/rs/ext/RuntimeDelegate.class
at javax.ws.rs.ext.RuntimeDelegate.findDelegate(RuntimeDelegate.java:146)
at javax.ws.rs.ext.RuntimeDelegate.getInstance(RuntimeDelegate.java:120)
at javax.ws.rs.core.MediaType.valueOf(MediaType.java:179)
at org.glassfish.jersey.media.sse.SseFeature.<clinit>(SseFeature.java:62)
at org.eclipse.smarthome.io.rest.sse.internal.SseActivator.start(SseActivator.java:44)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at java.security.AccessController.doPrivileged(Native Method)[:1.8.0_121]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
... 14 more
2017-04-14 07:07:39.754 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxxx, base URL = http://localhost:8080)
2017-04-14 07:07:40.383 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-04-14 07:07:42.071 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-astro': Error restarting bundles
