i’ve developed some bindings for OH2 and was wondering, if any others want to use these bindings cause i found no similar ones. At the moment there are:
a simple app is included to enroll a finger, and save them with a uid, name and picture to a database
the scanning process in OH2 is started with the help of a switch (e.g. over rules) (libfprint doesnt support polling so far as i know)
the scanned finger is compared to the fingers in the database and if a match is found, the informations (uid, name) is returned (at the moment the name is set to an Item).
Binding for a Barcodescanner (Honeywell):
scans the tag and set the value to a string item
at the moment it should only run under linux
Binding for Kodi:
simple client for kodi, to access it via jsonrpc
can send a notification to kodi with the help of a string item (simple post a string command to this item)
the client can also start playing of a file(video, sound) or show an image
the client should also be easy to extend
For me, the Bindings do what I want, but the setup for nfc-reader and fingerprint reader needs a bit more attention.
I use them on Ubuntu cause for Windows it can be very hard to compile the source for libnfc and libfprint.
If anybody is interested, the code is on https://github.com/andiikaa/openhab2 under bindings.
I can also upload the code for the nfc-reader and the fingerprint reader to github.
Hey André,
Thanks for sharing, I was looking for Kodi/Openhab2 binding and up to now only found the one you proposed.
I just tried to use your Kodi binding, but I get the following issue:
@runtime: org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.kodi [125] Unresolved requirement: Import-Package: org.eclipse.jetty.client; version=“9.2.9”
I modified org.openhab.binding.kodi\META-INF\MANIFEST.MF , similarly to the one in avmfritz . But that does not seem to help.
Any feedback for a newbie is welcome.
@tijeanhimself
Hi, do you load the jetty client plugin (in Eclipse: Run Configurations -> PlugIns)?
As i was looking for a kodi binding, i´ve forgotten to search after a XBMC binding (XBMC was renamed to kodi). There is already a binding for OH 1, which has much more functions and should also run in OH2.
Hope that helps.
@TommySharp
The NFC Library can also work under windows. Unfortunately, the binaries have to be compiled by your own (crosscompiling). The library works with a lot of nfc readers. Also, there are already some Java Wrappers (with other native libs) for nfc devices, but none of them worked with the one i have (http://www.nfc-tag-shop.de/en/nfc-hardware/21/nfc-usb-stick-nxp-pn533-reader/writer).
I have not much experience in crosscompiling and JNA/JNI. I know, the native nfc library can be wrapped into the Java Project (also for different Plattforms e.g. linux and win) . This would make the installation process much easier.
Unfortunately i have not much time at the moment, to work on it. But i can share the code for the libnfc Java Wrapper, if somebody want´s to use it.
I am very interesting about the NFC binding. Is this still under development and compatible to the openhab2.0 release? Such a binding would be very helpful for me.
Are there any plans to proceed with the development?
