I’m scratching my head on this one. I’ve got both the Nest & Weather bindings installed and both are exhibiting the same behavior.
Both bindings are installed via the Paper extension dashboard 2.0 B3.
Both bindings have valid nest.cfg & weather.cfg files in the conf/services folder
When launching weather I get the following then absolutely nothing…
11:02:38.779 [DEBUG] [org.openhab.binding.weather ] - BundleEvent INSTALLED - org.openhab.binding.weather
11:02:38.863 [DEBUG] [org.openhab.binding.weather ] - BundleEvent RESOLVED - org.openhab.binding.weather
11:02:38.896 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTING - org.openhab.binding.weather
11:02:38.928 [DEBUG] [eather.internal.bus.WeatherActivator] - Weather binding has been started.
11:02:38.933 [DEBUG] [org.openhab.binding.weather ] - BundleEvent STARTED - org.openhab.binding.weather
11:02:38.942 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.weather.WeatherBindingProvider}={component.name=org.openhab.binding.weather.genericbindingprovider, component.id=201, service.id=364, service.bundleid=211, service.scope=bundle} - org.openhab.binding.weather
11:02:38.944 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService, org.osgi.service.event.EventHandler}={event.topics=openhab/command/*, service.pid=org.openhab.weather, component.name=org.openhab.binding.weather, component.id=200, service.id=365, service.bundleid=211, service.scope=bundle} - org.openhab.binding.weather
11:02:39.024 [DEBUG] [al.bus.WeatherGenericBindingProvider] - Adding item Weather_Temperature with WeatherBindingConfig[locationId=home,type=temperature,property=current,roundingMode=HALF_UP,scale=2,unit=FAHRENHEIT]
11:02:39.031 [DEBUG] [.weather.internal.gfx.WeatherServlet] - Starting up weather servlet at /weather
11:02:39.732 [DEBUG] [org.openhab.binding.weather ] - ServiceEvent REGISTERED - {javax.servlet.ServletContext}={osgi.web.symbolicname=org.openhab.binding.weather, osgi.web.version=1.9.0.b3, osgi.web.contextpath=/, service.id=367, service.bundleid=211, service.scope=singleton} - org.openhab.binding.weather
When launching Nest, I get the following then nothing…
08:35:51.973 [DEBUG] [org.openhab.binding.nest ] - BundleEvent STARTING - org.openhab.binding.nest
08:35:51.990 [DEBUG] [.binding.nest.internal.NestActivator] - Nest binding has been started. Version 1.9.0.b3
08:35:51.990 [DEBUG] [org.openhab.binding.nest ] - BundleEvent STARTED - org.openhab.binding.nest
08:35:52.007 [DEBUG] [org.openhab.binding.nest ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.nest.NestBindingProvider}={component.name=org.openhab.binding.nest.genericbindingprovider, component.id=168, service.id=307, service.bundleid=204, service.scope=bundle} - org.openhab.binding.nest
08:35:52.066 [DEBUG] [org.openhab.binding.nest ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService}={event.topics=openhab/*, service.pid=org.openhab.nest, component.name=org.openhab.binding.nest.binding, component.id=167, service.id=309, service.bundleid=204, service.scope=bundle} - org.openhab.binding.nest
I did try pulling out the weather 2.0 binding and dropping in the 1.8x version. When launching that I get these errors
10:59:13.128 [ERROR] [org.openhab.binding.weather ] - [org.openhab.binding.weather(194)] bind method [addBindingProvider] not found; Component will fail
10:59:13.133 [ERROR] [org.openhab.binding.weather ] - [org.openhab.binding.weather(194)] bind method [addBindingProvider] not found
10:59:13.245 [ERROR] [org.openhab.binding.weather ] - [org.openhab.binding.weather(194)] unbind method [removeBindingProvider] not found; Component will fail
10:59:13.246 [ERROR] [org.openhab.binding.weather ] - [org.openhab.binding.weather(194)] unbind method [removeBindingProvider] not found
10:59:13.248 [ERROR] [org.openhab.binding.weather ] - [org.openhab.binding.weather(194)] bind method [addBindingProvider] not found
Any ideas?
I’m migrating to OpenHAB after playing with HomeSeer, Indigo, and Home Assistant. OpenHAB has everything I want, but this is the last thing I’m stuck on!
