Hi, I am a new user of OH3. I have installed OH3 on RPI4 2GB RAM model connected with Wi-Fi.
I have installed Bluetooth Binding (Bluetooth BlueZ Adaptor) and I am able to search the Bluetooth devices and add them as things and link them to items.
I have connected a BLE beacon and linked it to an item, the issues I am facing is as below:
- The Beacon once powered ON, is discovered by BlueZ Adaptor and the Thing status changes to ONLINE, as expected, but if I power off the beacon, the status never changes to OFFLINE, it remains ONLINE. (Is this also expected behavior).
- When its first time ONLINE it updates the RSSI value, but the change in the RSSI value is very infrequent even if I am moving the beacon.
- Beacon configuration does not have polling interval or scan interval settings, is there anyway I can set the scan interval, I want the beacons to be scanned every 10 seconds. If not available Thing status should change to OFFLINE.
My requirement:
I want to use beacons as presence detection, so want the thing status to change ONLINE and OFFLINE within few seconds.
Beacon I am using is Trackr Pixel.
