Blinds control - weather/astro
Hi, I need help with my blind control, I already can open it and close, when I want, but I would like to connect it to weather. If the temperature is higher than 25 Celsius, then close the blinds and if it’s under 25 Celsius open the blind. The other option is when it’s sunrise then open my blind, and at sunset close my blind.
I found there astro binding, and weather bindings, but don’t know how to use them. If you could help me explain it step by step it would be awesome.
The items I already used:
Dimmer MKBlindsControl1 "MK Blinds [%s]" <rollershutter> [ "Lighting" ] {mqtt=">[broker:MK-SmartHouse/utilities/MK-BlindsControl1:command:*:default]"}
https://docs.openhab.org/addons/bindings/astro/readme.html
https://docs.openhab.org/addons/bindings/weather1/readme.html
And if you have understood and successfully installed those bindings start reading the Rules documentation.
If you done all that and you need further input use the search function in here, such question has been asked and answered before.
