I’m trying to get this solution to work -but because its “closed” I can ask directly
The questions are simple. When I try the first step I get the following error:
curl: (60) SSL: no alternative certificate subject name matches target host name 'rest.prod.immedia-semi.com'
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
have a look to the certificate properties vs. the servers name ( URL ):
while the servers name is rest.prod.immedia-semi.com the subject alt names are cloudfront.net, *.cloudfront.net. This part of the certificate also needs to list the rest.prod.immedia-semi.com server name.
I hope someone does do a binding and I don’t want to discourage that in any way. however you do need to consider what will happen if any of the clouds you are relying on either charge a huge monthly fee or switch off support altogether. At some point it is smarter to purchase hardware that works 100% locally with no cloud needed and no ongoing fees.
Especially with the global economy we may see some companies close.
