Dear all,
I would like to share my setup for the Blitzwolf Socket (Tasmota flashed).
(For newer versions please select “Gosund SP1 v23” as Tasmota Module Type in the Web-Config GUI)
mosquitto.things
Thing topic bwshp2_1234 "Blitzwolf SHP2 #1 (blitzwolf-1234)" @ "MQTT" {
Channels:
Type switch : BW_1234_powerswitch "Blitzwolf SHP2 #1: Power Switch" [ stateTopic="tasmota/blitzwolf-1234/stat/POWER", commandTopic="tasmota/blitzwolf-1234/cmnd/POWER", on="ON", off="OFF" ]
Type switch : BW_1234_powerswitchres "Blitzwolf SHP2 #1: Switch State" [ stateTopic="tasmota/blitzwolf-1234/stat/RESULT", transformationPattern="JSONPATH:$.POWER",on="ON",off="OFF"]
Type string : BW_1234_time "Blitzwolf SHP2 #1: Time" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Time" ]
Type string : BW_1234_uptime "Blitzwolf SHP2 #1: Uptime" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Uptime" ]
Type number : BW_1234_vcc "Blitzwolf SHP2 #1: VCC" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Vcc" ]
Type string : BW_1234_ap "Blitzwolf SHP2 #1: Wifi AP" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Wifi.AP" ]
Type string : BW_1234_ssid "Blitzwolf SHP2 #1: Wifi SSID" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Wifi.SSId" ]
Type string : BW_1234_channel "Blitzwolf SHP2 #1: Wifi Channel" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Wifi.Channel" ]
Type number : BW_1234_rssi "Blitzwolf SHP2 #1: Wifi RSSI" [ stateTopic="tasmota/blitzwolf-1234/tele/STATE", transformationPattern="JSONPATH:$.Wifi.RSSI" ]
Type string : BW_1234_sensortime "Blitzwolf SHP2 #1: Sensor Time" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.Time" ]
Type string : BW_1234_starttime "Blitzwolf SHP2 #1: Start Time" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.TotalStartTime" ]
Type number : BW_1234_total "Blitzwolf SHP2 #1: Total" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Total" ]
Type number : BW_1234_yesterday "Blitzwolf SHP2 #1: Yesterday" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Yesterday" ]
Type number : BW_1234_today "Blitzwolf SHP2 #1: Today" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Today" ]
Type number : BW_1234_period "Blitzwolf SHP2 #1: Period" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Period" ]
Type number : BW_1234_apparent "Blitzwolf SHP2 #1: Apparent Power" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.ApparentPower" ]
Type number : BW_1234_reactive "Blitzwolf SHP2 #1: Reactive Power" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.ReactivePower" ]
Type number : BW_1234_factor "Blitzwolf SHP2 #1: Factor" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Factor" ]
Type number : BW_1234_power "Blitzwolf SHP2 #1: Power" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Power" ]
Type number : BW_1234_voltage "Blitzwolf SHP2 #1: Voltage" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Voltage" ]
Type number : BW_1234_current "Blitzwolf SHP2 #1: Current" [ stateTopic="tasmota/blitzwolf-1234/tele/SENSOR", transformationPattern="JSONPATH:$.ENERGY.Current" ]
Type string : BW_1234_devicestate "Blitzwolf SHP2 #1: Device State" [ stateTopic="tasmota/blitzwolf-1234/tele/LWT" ]
blitzwolf.items
// Blitzwolf BW-SHP2 #1 (1234)
Switch BW1_Switch "Blitzwolf#1: Switch 1" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_powerswitch" }
Switch BW1_State "Blitzwolf#1: State 1" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_powerswitchres"}
Number BW1_Vcc "Blitzwolf#1: VCC [%s]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_vcc" }
String BW1_WifiAp "Blitzwolf#1: Wifi AP [%s]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_ap" }
String BW1_WifiSsid "Blitzwolf#1: Wifi SSID [%s]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_ssid" }
String BW1_WifiChannel "Blitzwolf#1: Wifi Channel [%s]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_channel" }
Number BW1_WifiRssi "Blitzwolf#1: Wifi RSSI [%s]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_rssi" }
String BW1_Uptime "Blitzwolf#1: Uptime" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_uptime" }
String BW1_Time "Blitzwolf#1: Time" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_time" }
String BW1_DeviceState "Blitzwolf#1: Device State" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_devicestate" }
String BW1_SensorTime "Blitzwolf#1: Sensor Time" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_sensortime" }
String BW1_startTime "Blitzwolf#1: Start Time" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_starttime" }
Number BW1_Total "Blitzwolf#1: Total [%.3f kWh]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_total" }
Number BW1_Yesterday "Blitzwolf#1: Yesterday [%.3f kWh]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_yesterday" }
Number BW1_Today "Blitzwolf#1: Today [%.3f kWh]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_today" }
Number BW1_Period "Blitzwolf#1: Period" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_period" }
Number BW1_Apparent "Blitzwolf#1: Apparent" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_apparent" }
Number BW1_Reactive "Blitzwolf#1: Reactive" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_reactive" }
Number BW1_Factor "Blitzwolf#1: Factor [%.1f]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_factor" }
Number BW1_Power "Blitzwolf#1: Power [%.3f W]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_power" }
Number BW1_Voltage "Blitzwolf#1: Voltage [%.1f V]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_voltage" }
Number BW1_Current "Blitzwolf#1: Current [%.3f A]" { channel="mqtt:topic:mosquitto:bwshp2_1234:BW_1234_current" }
