I have a couple of lightbulbs from blitzwolf with Tasmota 8.1 installed on them. They are rgbww. Issue that I have is that the brightness of the bulb is not high if I set it through openhab. If I use do it from the Tasmota web web interface I can bring up the brightness. I looks like the colorwheel only sends rgb and not the “W”.
Below are some log entries from Tasmota and the thing/items that I have.
{“POWER”:“ON”,“Dimmer”:100,“Color”:“13,255,245,0”,“HSBColor”:“178,95,100”,“Channel”:
[5,100,96,0]}
{“POWER”:“ON”,“Dimmer”:100,“Color”:“FFFFFFFF”,“HSBColor”:“0,0,100”,“Channel”:[100,100,100,100]}
if I enter color 255,255,255,255 or FFFFFFFF in the console the bulb becomes bright. Is there any way to use 8 digits instead of 6 in the colorwheel?
thing
Type switch : power “Power” [ stateTopic=“stat/light/POWER”, commandTopic=“cmnd/light/POWER” ]
Type dimmer : dimmer “dimmer” [ stateTopic=“stat/light/STATE”, commandTopic=“cmnd/light/Dimmer” ]
Type colorHSB : color “color”[ stateTopic=“stat/light/STATE”, commandTopic=“cmnd/light/Color” ]items
Switch light_Power “Power []” <sonoff_pow> (light, gpower) {autoupdate=“false”,channel=“mqtt:topic:mosquitto:light:power” }
Dimmer light_Dimmer “Dimmer” (light) { channel=“mqtt:topic:mosquitto:light:dimmer” }
Color light_Color “ColorRGBCW hex [ox%s]” (light) { channel=“mqtt:topic:mosquitto:light:color” }sitemap
Slider item=light_Dimmer icon=dimmer label=“Dimmer”
Colorpicker item=light_Color icon=colorwheel label=“Color [%s]”
Text item=light_RSSI icon=network label=“WiFi Signal Strength [%d %%]”
Model BW-LT21
Material PC+PPT
Product Size D70H134MM
Package Size 7575145MM
Net Weight 135g
Weight 170g
Input Voltage AC100-240V 50/60HZ
Wattage 10W
Lumen 900LM
LED 6PcsRGB SMD5050+20Pcs*WW SMD2835
Color Temperature 3000K+RGB
Connection 2.4GHz Wi-Fi 802.11 b/g/n
