Hi
Is it possible to import data from a file (txt or excel) using blockly?
/torben
I don’t think so, at least not with native Blocks. The easiest way I’ve found to do this in any rule language is to call executeCommandLine and cat the contents of the file.
I don’t see a block nor a block library for executeCommandLine so you could use the inline script block with something like
var Duration = Java.type('java.time.Duration');
var fileContents = actions.Exec.executeCommandLine(Duration.ofSeconds(1), 'cat', '/path/to/file');
fileContents
will be a String containing the contents of the file.
