I’m currently trying to move my rules from an old OH2 setup to a new OH3 install and thought I’d try to use everything UI and Blockly.
Things are going well so far but I have come into an issue with Blockly and groups.
I know in DSL you can code it so that do something when a member of a group changes / updates etc and you can then get which particular member to use it in the next part of the rule.
I can’t seem to find this option in Blockly, there is a ‘get members of group’ but that just does the first part of the DSL coding, what I really need is for it to them tell me which one changed so I can do something to it…
Are you testing the blockly action by pressing the play button? The event object is only injected into a rule when it is actually run by one of the triggers.
